Cisco Business 802.11ac Wave 2 Access Po
Quicklinx: G523WS00 Mfr#: CBW240AC-E
  • IEEE 802.11n
Hurry, only 2 left in stock!
£139.42 ex VAT
£167.30 inc VAT
The Cisco Business 240AC Access Point delivers high density MU-MIMO (4x4) wireless connectivity for small offices. Designed with simplicity, flexibility and security in mind, the Cisco Business 240AC provides superior performance and enhanced range for an optimal user experience.
Compatible with Cisco Business 100 Series Mesh Extenders to rapidly expand your Wi-Fi network.
  • PERFORMANCE
    Superior MU-MIMO (4x4) performance supporting up to 200 wireless devices and a maximum wireless coverage up to 3000 square feet
  • DEPLOYMENT
    Flexible deployment wall or celling mount (brackets included). Works also with Cisco Business Power over Ethernet injector (CB-PWRINJ)
  • ENHANCED COVERAGE
    Supports up to 25 mesh extenders while delivering a reliable user experience
  • SET UP IN MINUTES
    Simplify management and monitor your network from Cisco Business Mobile app or web browser
  • ADVANCED SECURITY
    Enterprise-class security prevent malware, phishing, and other threats from compromising your network via Cisco Umbrella integration
Cisco Business 240AC - radio access point - Wi-Fi 5
Radio access point
External
RAM
1 GB
Flash Memory
256 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (5 GHz): 1733 Mbps
Wireless clients per Wi-Fi radio: 200 , Wireless clients: 400 , VLANs supported: 16
Power Over Ethernet (PoE) Supported
PoE+
17.8 cm x 17.8 cm x 3.8 cm
430 g
Radio access point
17.8 cm
17.8 cm
3.8 cm
430 g
Processor / Memory / Storage
RAM
1 GB
Flash Memory
256 MB
External
Wireless
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
Status
VLAN support, manageable, DFS support, Mesh networking, Wi-Fi Multimedia (WMM) support, RADIUS support, ceiling mountable, 802.1x authentication, beamforming technology, Authentication, Authorization and Accounting (AAA), 4x4 MU-MIMO technology
Encryption Algorithm
AES, TLS, PEAP, TTLS, WPA2, WPA3
Authentication Method
RADIUS, MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.3, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11n, IEEE 802.3at, IEEE 802.11r, IEEE 802.11ac Wave 2, IEEE 802.11ac Wave 1
Aerial
Antenna
Internal
Antenna Qty
2
Directivity
Omni-directional
2 x 1000Base-T (PoE+) - RJ-45
EN55024, AS/NZS 60950-1, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, VCCI V-3, CECP, EN 62209-1, SRRC, CNS 13438, EN 50385, EN 61000-3-3:2013, CISPR 24:2010, EN 62209-2, EN 60601-1-1, EN 61000-3-2:2014, LP0002, RSS-247, NRCAN, KN32, EN 55032:2012+AC:2013 Class A, TCVN 7189, EN 55032:2015, ICES-003 issue 6 Class B, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17 V3.1.1 (2017), EN 300 328 V2.1.1, EN 55035, AS/NZS 2772, EN 301 489-1 V2.1.1:2017, AS/NZS CISPR 32:2015, CISPR 32:2015, ARPANSA, KN 61000-3-2, KN 61000-3-3, KN 489-1, QCVN, KN 489-17, RSP-100, RSS-GEN, EN 301 893 V2.1.1, AS/NZS 4268:2017
PoE+
13.2 Watt
Limited warranty - replacement - lifetime
-30 °C
70 °C
10 - 90% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Protocol: IEEE 802.11ac Wave 2
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Brand: Cisco
