Cisco ASA 5550 Appliance
Quicklinx: 5C7FWS00 Mfr#: ASA5550-BUN-K9
The Cisco ASA 5500 Series Firewall Edition enables businesses to securely deploy mission-critical applications and networks in a highly reliable manner, while providing significant investment protection and lower operational costs through its unique, modular design. Businesses can protect their networks from unauthorized access using the Cisco ASA 5500 Series Firewall Edition's robust policy enforcement services. These services combine with market-leading VPN services to enable businesses to securely extend their networks across low-cost Internet connections to business partners, remote sites, and mobile workers. This flexible solution can adapt as an organization's needs evolve along with the ever-changing security threat landscape, giving businesses the ability to easily integrate market-leading intrusion prevention, antivirus, antispam, antispyware, URL filtering, and other advanced content security services for additional layers of protection. Combined with Cisco management and monitoring application solutions, the Cisco ASA 5500 Series Firewall Edition provides world-class security with lower operational costs.
Cisco ASA 5550 Firewall Edition Bundle - security appliance
Security appliance
Rack-mountable - 1U
RAM
4 GB
Flash Memory
64 MB
Performance
VPN throughput: 425 Mbps , Firewall throughput: 1.2 Gbps
SSL VPN peers: 2 , IPSec VPN peers: 5000 , Virtual interfaces (VLANs): 250
44.5 cm x 33.5 cm x 4.4 cm
10 kg
Security appliance
Height (Rack Units)
1U
44.5 cm
33.5 cm
4.4 cm
10 kg
Processor / Memory / Storage
RAM
4 GB
Flash Memory
64 MB
Rack-mountable
Wired
Network / Transport Protocol
IPSec
Performance
Firewall protection, VPN support, load balancing, VLAN support, High Availability
Encryption Algorithm
DES, Triple DES, AES, SSL
Expansion Slots
4 (total) / 4 (free) x SFP (mini-GBIC) , 1 memory
8 x 1000Base-T - RJ-45 , 1 x 100Base-TX - RJ-45 , 1 x serial , 2 x USB 2.0 - Type A , 1 x management - RJ-45
FCC Class A certified, CISPR 22 Class A, EN 60950, EN 61000-3-2, UL 1950, VCCI Class A ITE, IEC 60950, EN 61000-3-3, CSA 22.2 No. 950, EN55022 Class A, ACA TS001, AS/NZS 3260, FCC Part 15
Internal power supply
5 - 95%
