Cisco ASA 5525-X with FirePOWER Services, 8GE, AC, 3DES/AES, SSD
Quicklinx: DYVWWS00 Mfr#: ASA5525-FPWR-K9#1001681913
Midsize businesses protecting the Internet edge require the same level of protection as large, enterprise networks. You require enterprise-strength security, but purchasing a firewall that was built to handle the performance needs and budget of a large enterprise would be unnecessary and a waste of company resources. You need a firewall that provides the performance you need at a price you can afford, without compromising security.
Cisco ASA 5500 series adaptive security appliance fits your network and budget while offering the same proven level of security that protects some of the largest networks at some of the most security-conscious companies in the world. The ASA 5500 series scales to meet the performance and security requirements of a wide range of network applications, to correspond with your changing needs.
The Cisco ASA 5525-X is midrange security appliance that uses the Cisco SecureX framework for a context-aware approach to security that delivers multiple security services, multigigabit performance, flexible interface options, and redundant power supplies. It is built on the same proven security platform as the rest of the ASA family of security appliances, and has been designed to deliver superior performance for exceptional operational efficiency.
  • Robust security
    The Cisco ASA 5525-X security appliance offers comprehensive firewall protection and VPN support, ensuring your network remains secure against threats.
  • High performance
    With a throughput of up to 2 Gbps, the Cisco ASA 5525-X handles high traffic volumes efficiently, making it suitable for growing businesses.
  • Flexible connectivity
    Equipped with eight 1000Base-T ports and additional management and USB interfaces, this device offers versatile connectivity options for a variety of network configurations.
  • Advanced environmental adaptability
    Designed to operate within a wide range of temperatures, from -5°C to 40°C, the Cisco ASA 5525-X ensures reliability in diverse operating environments.
  • Scalable network expansion
    Support for up to 750 IPSec VPN peers and 200 virtual interfaces (VLANs) allows for scalable network expansion to meet future demands.
Cisco ASA 5525-X - security appliance - with FirePOWER Services
Security appliance
Rack-mountable - 1U
RAM
8 GB
Flash Memory
8 GB
Hard Drive
1
Ports Qty
8
Gigabit Ethernet
Performance
Firewall throughput: 2 Gbps , VPN throughput (3DES/AES): 300 Mbps , Connection rate: 20000 connections per second , Firewall + intrusion prevention throughput: 600 Mbps
IPSec VPN peers: 750 , SSL VPN peers: 2 , Concurrent sessions: 500000 , Virtual interfaces (VLANs): 200 , Security contexts: 2
Pricing Type
Refurbished
42.9 cm x 39.5 cm x 4.24 cm
6.77 kg
90 days warranty
Bundled with
FirePOWER Services
Security appliance
Height (Rack Units)
1U
42.9 cm
39.5 cm
4.24 cm
6.77 kg
Bundled with
FirePOWER Services
Processor / Memory / Storage
RAM
8 GB
Flash Memory
8 GB
Hard Drive
SSD 1
Rack-mountable
Ports Qty
8
Wired
Gigabit Ethernet
Network / Transport Protocol
IPSec
Performance
Status Indicators
Power, Boot State, HDD activity, active, alarm, VPN
Firewall protection, VPN support, VLAN support, High Availability
Encryption Algorithm
DES, Triple DES, AES
Expansion Slots
1 (total) / 1 (free) x expansion slot
8 x 1000Base-T - RJ-45 , 1 x 1000Base-T (management) - RJ-45 , 1 x management - RJ-45 , 2 x USB 2.0 - Type A
C-Tick, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EMC, EN 60950-1, UL 60950-1 Second Edition, FCC Part 15 B Class A, VCCI V-3, KC, IEC 60950-1 Second Edition, CSA C22.2 No. 60950-1-07 Second Edition
Pricing Type
Refurbished
Internal power supply
Installed Qty
1
Max Supported Qty
1
Power Provided
400 Watt
Software Included
Drivers & Utilities
Limited warranty - advance parts replacement - 90 days - response time: 10 days
-5 °C
