Cisco ASA 5525-X Firewall Edition Security Appliance 8 Ports 1U
Quicklinx: CGSPWS00 Mfr#: ASA5525-K9
£5,380.94 ex VAT
£6,457.12 inc VAT
Midsize businesses protecting the Internet edge require the same level of protection as large, enterprise networks. You require enterprise-strength security, but purchasing a firewall that was built to handle the performance needs and budget of a large enterprise would be unnecessary and a waste of company resources. You need a firewall that provides the performance you need at a price you can afford, without compromising security.
Cisco ASA 5500 series adaptive security appliance fits your network and budget while offering the same proven level of security that protects some of the largest networks at some of the most security-conscious companies in the world. The ASA 5500 series scales to meet the performance and security requirements of a wide range of network applications, to correspond with your changing needs.
The Cisco ASA 5525-X is midrange security appliance that uses the Cisco SecureX framework for a context-aware approach to security that delivers multiple security services, multigigabit performance, flexible interface options, and redundant power supplies. It is built on the same proven security platform as the rest of the ASA family of security appliances, and has been designed to deliver superior performance for exceptional operational efficiency.
Cisco ASA 5525-X Firewall Edition - security appliance
Security appliance
Rack-mountable - 1U
RAM
12 GB
Ports Qty
8
Gigabit Ethernet
Performance
Firewall throughput: 2 Gbps , VPN throughput (3DES/AES): 300 Mbps , Connection rate: 20000 connections per second , Firewall + intrusion prevention throughput: 600 Mbps
IPSec VPN peers: 750 , SSL VPN peers: 2 , Concurrent sessions: 500000 , Virtual interfaces (VLANs): 200 , Security contexts: 2
42.9 cm x 39.5 cm x 4.24 cm
6.77 kg
90 days warranty
Security appliance
Height (Rack Units)
1U
42.9 cm
39.5 cm
4.24 cm
6.77 kg
Processor / Memory / Storage
RAM
12 GB
Rack-mountable
Ports Qty
8
Wired
Gigabit Ethernet
Network / Transport Protocol
IPSec
Performance
Status Indicators
Power, Boot State, HDD activity, active, alarm, VPN
Firewall protection, VPN support, VLAN support, High Availability
Encryption Algorithm
DES, Triple DES
Expansion Slots
1 (total) / 1 (free) x expansion slot
8 x 1000Base-T - RJ-45 , 1 x 1000Base-T (management) - RJ-45 , 1 x management - RJ-45 , 2 x USB 2.0 - Type A
Rack Mounting Kit
Included
C-Tick, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EMC, EN 60950-1, UL 60950-1 Second Edition, FCC Part 15 B Class A, VCCI V-3, KC, IEC 60950-1 Second Edition, CSA C22.2 No. 60950-1-07 Second Edition
Internal power supply
Software Included
Cisco VPN Client
Limited warranty - advance parts replacement - 90 days - response time: 10 days
-5 °C
0 - 90%
