Cisco ASA 5520 Security Appliance
Quicklinx: 4CTHWS00 Mfr#: ASA5520-BUN-K9
The Cisco ASA 5520 Adaptive Security Appliance delivers a wide range of security services with Active/Active high availability and Gigabit Ethernet connectivity for medium-sized enterprise networks, in a modular, high performance appliance. Using its four Gigabit Ethernet interfaces and support for up to 25 VLANs, businesses can easily deploy these security services into multiple zones within their network. The Cisco ASA 5520 Adaptive Security Appliance scales with businesses as their network security requirements grow, delivering solid investment protection. Businesses can extend their IPSec and SSL VPN capacity through multiple means to support a larger number of mobile workers, remote sites, and business partners. VPN capacity can be increased by taking advantage of the integrated VPN clustering and load-balancing capabilities of the Cisco ASA 5520 Adaptive Security Appliance, as well as more than doubling each platform's VPN capacity through the installation of a VPN upgrade license. The advanced application layer security and anti-x defenses provided by the Cisco ASA 5520 Adaptive Security Appliance can be extended by deploying a high performance Security Services Module. Using the optional security context capabilities of the Cisco ASA 5520 Adaptive Security Appliance, businesses can deploy up to 10 virtual firewalls within an appliance to enable compartmentalized control of security policies on a departmental level. This virtualization strengthens security and reduces overall management and support costs while consolidating multiple security devices into a single appliance.
  • Robust security
    The Cisco ASA 5520 is designed with firewall protection, VPN support, and VLAN support, ensuring a secure network environment for businesses of all sizes. Its comprehensive security features safeguard your data from unauthorized access and threats.
  • High performance
    With a firewall throughput of up to 450 Mbps, the Cisco ASA 5520 delivers the performance needed to support a wide range of applications and services. This ensures smooth and reliable operation, even in demanding network environments.
  • Flexible connectivity
    Equipped with Gigabit Ethernet data link protocol and multiple RJ-45 connectors, this security appliance offers versatile connectivity options. It supports wired connections, making it suitable for a variety of network setups.
Cisco ASA 5520 - Firewall Edition - security appliance
Security appliance
Rack-mountable - 1U
RAM
2 GB
Flash Memory
256 MB
Gigabit Ethernet
Performance
Firewall throughput: 450 Mbps , VPN throughput (3DES/AES): 225 Mbps , Connection rate: 12000 connections per second
Concurrent sessions: 280000 , IPSec VPN peers: 750 , SSL VPN peers: 2 , Virtual interfaces (VLANs): 150 , Security contexts: 20
36.2 cm x 20.04 cm x 4.45 cm
9.07 kg
90 days warranty
Security appliance
Height (Rack Units)
1U
Installed Modules Qty (Max)
0 (1)
36.2 cm
20.04 cm
4.45 cm
9.07 kg
Processor / Memory / Storage
RAM
2 GB
Flash Memory
256 MB
Rack-mountable
Wired
Gigabit Ethernet
Network / Transport Protocol
IPSec
Performance
Firewall protection, VPN support, load balancing, VLAN support, High Availability
Encryption Algorithm
DES, Triple DES, AES
Expansion Slots
1 (total) / 1 (free) x expansion slot
1 x 100Base-TX - RJ-45 , 1 x management - RJ-45 , 2 x USB 2.0 - Type A , 1 x serial , 4 x 1000Base-T - RJ-45
FCC Class A certified, CISPR 22 Class A, EN 60950, EN 61000-3-2, UL 1950, VCCI Class A ITE, IEC 60950, EN 61000-3-3, CSA 22.2 No. 950, EN55022 Class A, ACA TS001, AS/NZS 3260, FCC Part 15
Internal power supply
Power Provided
190 watt
Limited warranty - advance parts replacement - 90 days - response time: 10 days
5 - 95%
