Cisco ASA 5515-X Firewall Edition Security Appliance
Quicklinx: 9CZ7WS00 Mfr#: ASA5515-K9
A key component of the Cisco SecureX framework, the Cisco ASA 5500 series integrates the world's most proven firewall with a robust suite of highly integrated, security services for networks of all sizes - small and midsize business with one or a few locations, large enterprises, service providers, and mission-critical data centers. The Cisco ASA 5500 series delivers MultiScale performance and functionality with unprecedented services flexibility, modular scalability, feature extensibility, and lower deployment and operations costs.
The Cisco ASA 5515-X midrange security appliance uses the Cisco SecureX framework for a context-aware, network-centric approach to security that enables consistent security enforcement throughout the organization. It is built on the same proven security platform as the rest of the ASA family of security appliances, and has been designed to deliver superior performance for exceptional operational efficiency.
With up to 1.2 Gbps of firewall throughput, 250,000 concurrent firewall connections, 15,000 connections per second, and 6 integrated 10/100/1000 Fast Ethernet interfaces, the ASA 5515-X is the excellent choice for businesses requiring a high-performance, cost-effective, extensible security solution that can grow with their changing needs.
Cisco ASA 5515-X Firewall Edition - security appliance
Security appliance
Rack-mountable - 1U
RAM
8 GB
Ports Qty
6
Gigabit Ethernet
Performance
Firewall throughput: 1.2 Gbps , VPN throughput (3DES/AES): 250 Mbps , Connection rate: 15000 connections per second , Firewall + intrusion prevention throughput: 400 Mbps
IPSec VPN peers: 250 , SSL VPN peers: 2 , Concurrent sessions: 250000 , Virtual interfaces (VLANs): 100 , Security contexts: 2
42.9 cm x 39.5 cm x 4.2 cm
6.1 kg
90 days warranty
Security appliance
Height (Rack Units)
1U
42.9 cm
39.5 cm
4.2 cm
6.1 kg
Processor / Memory / Storage
RAM
8 GB
Rack-mountable
Ports Qty
6
Wired
Gigabit Ethernet
Performance
Status Indicators
Power, HDD activity, active, alarm
Firewall protection, VPN support, VLAN support
Encryption Algorithm
Triple DES, AES
Expansion Slots
1 (total) / 1 (free) x expansion slot
6 x 1000Base-T - RJ-45 , 1 x 1000Base-T (management) - RJ-45 , 1 x management - RJ-45 , 2 x USB 2.0 - Type A
Rack Mounting Kit
Included
VCCI, C-Tick, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 B Class A, CAN/CSA C22.2 No. 60950-1-07, ANSI C63.4-2009
Internal power supply
Software Included
Drivers & Utilities
Limited warranty - 90 days
-5 °C
10 - 90% (non-condensing)
9CZ7 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
