The Cisco ASA 5512-X midrange security appliance uses the Cisco SecureX framework for a context-aware, network-centric approach to security that enables consistent security enforcement throughout the organization. It is built on the same proven security platform as the rest of the ASA family of security appliances, and has been designed to deliver superior performance for exceptional operational efficiency.
- Cisco ASA 5512-X Firewall Edition - security appliance
- Security appliance
- Form Factor
- Rack-mountable - 1U
- RAM
- 4 GB
- Flash Memory
- 4 GB
- Ports Qty
- 6
- Data Link Protocol
- Gigabit Ethernet
- Performance
- Firewall throughput: 1 Gbps , VPN throughput (3DES/AES): 200 Mbps , Connection rate: 10000 connections per second , Firewall + intrusion prevention throughput: 250 Mbps
- Capacity
- IPSec VPN peers: 250 , SSL VPN peers: 2 , Concurrent sessions: 100000 , Virtual interfaces (VLANs): 50 , Security contexts: 2
- Power
- AC 120/230 V (50/60 Hz)
- 42.9 cm x 39.5 cm x 4.24 cm
- 6.1 kg
- 90 days warranty
- Height (Rack Units)
- 1U
- 42.9 cm
- 39.5 cm
- 4.24 cm
- 6.1 kg
Processor / Memory / Storage
- RAM
- 4 GB
- Flash Memory
- 4 GB
- Form Factor
- Rack-mountable
- Ports Qty
- 6
- Connectivity Technology
- Wired
- Gigabit Ethernet
- Performance
- Capacity
- Status Indicators
- Power, HDD activity, active, alarm
- Firewall protection, VPN support, VLAN support
- Encryption Algorithm
- Triple DES, AES
- Expansion Slots
- 1 (total) / 1 (free) x expansion slot
- 6 x 1000Base-T - RJ-45 , 1 x 1000Base-T (management) - RJ-45 , 1 x management - RJ-45 , 2 x USB 2.0 - Type A
- Rack Mounting Kit
- Included
- VCCI, C-Tick, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 B Class A, CAN/CSA C22.2 No. 60950-1-07, ANSI C63.4-2009
- Power Device
- Internal power supply
- Voltage Required
- Software Included
- Drivers & Utilities
- Limited warranty - advance parts replacement - 90 days - response time: 10 days
- -5 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
