The Cisco ASA 5510 Adaptive Security Appliance delivers a wealth of advanced security and networking services for small-to-medium businesses and enterprise remote/branch offices in an easy-to-deploy, cost-effective appliance. These services can be easily managed and monitored by the integrated, Web-based management application, Cisco Adaptive Security Device Manager, thus reducing the overall deployment and operations costs associated with providing this high level of security. The Cisco ASA 5510 Adaptive Security Appliance provides high performance firewall and VPN services, three integrated 10/100 Fast Ethernet interfaces, and optional high-performance intrusion prevention and anti-x services via a Security Services Module making it an excellent choice for businesses requiring a cost-effective, extensible, DMZ-enabled security solution. As business needs grow, the Cisco ASA 5510 Adaptive Security Appliance can also scale to higher interface density and integrate into switched network environments through VLAN support by installing a Security Plus upgrade license. Furthermore, this upgrade license maximizes business continuity by enabling Active/Standby high availability services and expands VPN capacity by supporting a greater number of concurrent VPN connections for mobile users, remote sites, and business partners.
- Cisco ASA 5510 Firewall Edition - security appliance
- Security appliance
- Form Factor
- Rack-mountable - 1U
- RAM
- 1 GB
- Flash Memory
- 256 MB
- Ports Qty
- 5
- Data Link Protocol
- Ethernet, Fast Ethernet
- Performance
- Firewall throughput: 300 Mbps , Connection rate: 9000 connections per second , VPN throughput: 170 Mbps
- Capacity
- IPSec VPN peers: 250 , SSL VPN peers: 2 , Concurrent sessions: 50000 , Virtual interfaces (VLANs): 50
- Power
- AC 120/230 V (50/60 Hz)
- 44.5 cm x 33.5 cm x 4.4 cm
- 9.1 kg
- Height (Rack Units)
- 1U
- Installed Modules Qty (Max)
- 0 (1)
- 44.5 cm
- 33.5 cm
- 4.4 cm
- 9.1 kg
Processor / Memory / Storage
- RAM
- 1 GB
- Flash Memory
- 256 MB
- Form Factor
- Rack-mountable
- Ports Qty
- 5
- Connectivity Technology
- Wired
- IPSec
- Performance
- Capacity
- VPN tunnels Qty
- 50 tunnels
- Firewall protection, VPN support, load balancing, VLAN support
- Encryption Algorithm
- DES, Triple DES, AES
- Expansion Slots
- 1 (total) / 1 (free) x expansion slot
- 5 x 100Base-TX - RJ-45 , 1 x 100Base-TX (management) , 1 x management - RJ-45 , 1 x serial , 2 x USB 2.0 - Type A
- FCC Class A certified, CISPR 22 Class A, EN 60950, EN 61000-3-2, UL 1950, VCCI Class A ITE, IEC 60950, EN 61000-3-3, CSA 22.2 No. 950, EN55022 Class A, ACA TS001, AS/NZS 3260, FCC Part 15
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 190 watt
- Software Included
- Drivers & Utilities
- 0 °C
- 40 °C
- 5 - 95%
