Cisco Aironet Power Injector products increase the deployment flexibility of Cisco Aironet wireless access points and bridges by providing an alternative powering option to local power, inline power-capable multiport switches, and multiport power patch panels.
- Cisco Aironet Power Injector - PoE injector - 15.4 watt
- PoE injector - external
- Input Voltage
- AC 100-240 V
- Power Capacity
- 15.4 watt
- Input Connectors
- Power IEC 60320 C14
- Output connectors
- 1 x RJ-45
- 16.5 cm x 6.5 cm x 3.6 cm
- Designed For
- Aironet 1602e Controller-based, 1602e Standalone, 1602i Controller-based, 1602i Standalone
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Input Connectors
- Power Output Connectors Details
- 1 x RJ-45
- Power Capacity
- 15.4 watt
- 1 x Gigabit LAN - RJ-45
- EN 60950, EN55022, IEC950, EN55024, UL 60950, CSA 22.2 No. 60950, ICES-003 Class B, FCC Part 15.107, FCC Part 15.109, AS/NZS 3548 Class B, VCCI Class B, EN 301 489-1, EN 301 489-17
- 16.5 cm
- 6.5 cm
- 3.6 cm
- Designed For
- Cisco Aironet 1602e Controller-based, 1602e Standalone, 1602i Controller-based, 1602i Standalone
