As this access point takes greater advantage of the multiple-input multiple-output (MIMO) features supported under the 802.11n standard, the number of radio transceivers per frequency band has increased. Using dual-band antenna port allows the access point to support these added transceivers while maintaining a reasonably low number of antenna connections.
                OMNIDIRECTIONAL WI-FI ANTENNA4 dBi (2.4 GHz)/7 dBi (5 GHz); suitable for use on Aironet outdoor access points
                CONNECTION AND MOUNTN-type male connector; direct mount on access point; no cable attachments
                360-DEGREE RADIATION PATTERNIntended for deployment when coverage in all directions from the antenna is required
                PERFORMANCEDesigned for improved coverage
                PEACE OF MIND1-year limited hardware warranty
- Cisco Aironet Dual Band Omni Antenna - antenna
- Product Type
- Antenna
- 3.2 cm x 3.2 cm x 28.2 cm
- 170 g
- Aerial Placing / Mounting
- Outdoor
- Frequency Range
- 2.4 - 2.483 GHz, 5 GHz, 5.15 - 5.875 GHz
- Gain
- 7 dBi (for 5 GHz), 4 dBi (for 2.4 GHz)
- Directivity
- Omni-directional
- Product Type
- Antenna
- 3.2 cm
- 3.2 cm
- 28.2 cm
- 170 g
Aerial
- Outdoor
- Frequency Range
- Gain
- Directivity
- Omni-directional
- Voltage Standing Wave Ratio (VSWR)
- 2.0:1
- Impedance
- 50 Ohm
Cabling & Wiring
- Connector Provided
- 1 x N-Series connector male
- -40 °C
- 85 °C
