Cisco Aironet Dual-Band Dipole Antenna
Quicklinx: 99SZWS00 Mfr#: AIR-ANT2524DW-R=
Type: Antennas
38 In Stock
£31.23 ex VAT
£37.47 inc VAT
As this access point takes greater advantage of the multiple-input multiple-output (MIMO) features supported under the 802.11n standard, the number of radio transceivers per frequency band has increased. Using dual-band antenna port allows the access point to support these added transceivers while maintaining a reasonably low number of antenna connections.
  • OMNIDIRECTIONAL WI-FI ANTENNA
    2 dBi (2.4 GHz)/4 dBi (5 GHz); white dipole (1 port); for use with Aironet 1830, 1850, 2800 and 3800 Series and Cisco Catalyst 9115AX, 9120AX and 9130AX Series access points
  • CONNECTION AND MOUNT
    RP-TNC connector
  • 360-DEGREE RADIATION PATTERN
    Intended for deployment when coverage in all directions from the antenna is required
  • PERFORMANCE
    Designed for improved coverage
  • PEACE OF MIND
    1-year limited hardware warranty
Cisco Aironet Dual-Band Dipole Antenna - antenna
Antenna
White
Aerial Placing / Mounting
Indoor
Frequency Range
2.4 GHz, 5 GHz
Gain
2 dBi, 4 dBi
Aironet 3602E
Antenna
Enclosure Colour
White
Aerial
Indoor
Frequency Range
2.4 GHz, 5 GHz
Gain
2 dBi, 4 dBi
Cisco Aironet 3602E
Type: Antennas
Brand: Cisco
