Cisco Aironet Dual-Band Dipole Antenna - Antenna - indoor - 2 dBi,
Quicklinx: B3B6WS00 Mfr#: AIR-ANT2524DG-R=
Type: Antennas
£32.16 ex VAT
£38.59 inc VAT
As this access point takes greater advantage of the multiple-input multiple-output (MIMO) features supported under the 802.11n standard, the number of radio transceivers per frequency band has increased. Using dual-band antenna port allows the access point to support these added transceivers while maintaining a reasonably low number of antenna connections.
  • Versatile placement
    Designed for indoor use, the Cisco Aironet Dual-Band Dipole Antenna offers flexible placement options, ensuring optimal signal reception and coverage in various indoor environments.
  • Dual-band functionality
    With frequency ranges in both 2.4 GHz and 5 GHz bands, this antenna supports dual-band functionality, allowing for enhanced performance and compatibility with a wide range of wireless access points.
  • Enhanced gain
    Featuring gains of 2 dBi for 2.4 GHz and 4 dBi for 5 GHz, the antenna is engineered to improve signal strength and extend coverage, making it an ideal solution for reliable wireless connectivity.
Cisco Aironet Dual-Band Dipole Antenna - antenna
Antenna
Grey
Aerial Placing / Mounting
Indoor
Frequency Range
2.4 GHz, 5 GHz
Gain
2 dBi, 4 dBi
Aironet 3602E
Antenna
Enclosure Colour
Grey
Aerial
Indoor
Frequency Range
2.4 GHz, 5 GHz
Gain
2 dBi, 4 dBi
Cisco Aironet 3602E
Type: Antennas
Brand: Cisco
