The Cisco Aironet 2700 series of Wi-Fi access points (APs) delivers industry-leading 802.11ac performance at a price point ideal for plugging capacity and coverage gaps in dense indoor environments. The Aironet 2700 series extends 802.11ac speed and features to a generation of smartphones, tablets, and high-performance laptops now shipping with the faster, 802.11ac Wi-Fi radios.
The Aironet 2700 series supports 802.11ac "Wave 1" in its first implementation, providing a theoretical connection rate of up to 1.3 Gbps. That's roughly triple the rates offered by today's high-end 802.11n APs. The boost helps you stay ahead of the performance and bandwidth expectations of today's mobile worker, who usually uses multiple Wi-Fi devices instead of just one. As such, users are adding proportionally larger traffic loads to the wireless LAN, which has outpaced Ethernet as the default enterprise access network.
Building on the Cisco Aironet heritage of RF excellence, the 2700 series APs run on a purpose-built, innovative chipset with a best-in-class RF architecture. This chipset provides a high-density experience for enterprise networks designed for mission-critical, high-performance applications.
Cross-AP noise reduction
Cross-AP noise reduction, a Cisco innovation enables APs to intelligently collaborate in real time about RF conditions so that users connect with optimized signal quality and performance. -
Optimized AP roaming
Optimized AP roaming ensures that client devices associate with the AP in their coverage range that offers the fastest data rate available. -
Cisco ClientLink 3.0 technology
Cisco ClientLink 3.0 technology improves downlink performance to all mobile devices, including one-, two-, and three-spatial-stream devices on 802.11ac. At the same time, the technology improves battery life on mobile devices. -
Cisco CleanAir technology
Cisco CleanAir technology enhanced with 80 MHz channel support. CleanAir delivers proactive, high-speed spectrum intelligence across 20-, 40-, and 80-MHz-wide channels to combat performance problems due to wireless interference. -
MIMO equalization
MIMO equalization capabilities, which optimize uplink performance and reliability by reducing the impact of signal fade.
- Cisco Aironet 2700i Access Point - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- RAM
- 512 MB
- Flash Memory
- 64 MB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- 22.1 cm x 22.1 cm x 5.1 cm
- 1 kg
- Limited lifetime warranty
- 22.1 cm
- 22.1 cm
- 5.1 cm
- 1 kg
Processor / Memory / Storage
- RAM
- 512 MB
- Flash Memory
- 64 MB
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 450 Mbps
- Line Coding Format
- CCK
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Status
- Auto-sensing per device, power over Ethernet (PoE), DFS support, Wi-Fi Multimedia (WMM) support, CleanAir technology, Maximum Ratio Combining (MRC), ClientLink 2.0 technology, 3T4R MIMO technology
- Encryption Algorithm
- AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2
- Authentication Method
- MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna
- Internal
- Directivity
- Omni-directional
- Gain Level
- 4 dBi
- 2 x 1000Base-T - RJ-45 , 1 x management - RJ-45
- VCCI, ICES-003, FCC Part 15.247, RSS-210, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, EN 300.489.1, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, EN50155, EMI, EN 300 328, EN 301 893, CAN/CSA-C22.2 No. 60950-1
- PoE
- 15 Watt
- Limited warranty - advance parts replacement - lifetime - response time: 10 days
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.25 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.00 |
