Ideal for small and medium-sized networks, the Cisco Aironet 1850 Series delivers industry-leading performance for enterprise and service provider markets via enterprise-class 4x4 MIMO, four-spatial-stream access points that support the IEEE's 802.11ac Wave 2 specification.
MU-MIMO
802.11ac Wave 2 with 4x4 Multiple-Input Multiple-Output (MIMO) technology with four spatial streams when operating in single-user MIMO mode and three spatial streams while operating in multi-user MIMO mode, offering 1.7 Gbps rates for more capacity and reliability than competing access points -
APPLICATION VISIBILITY AND CONTROL
Network Based Application Recognition (NBAR) deep-packet inspection technology provides application-aware control on a wireless network and enhances manageability and productivity. It also extends Cisco's Application Visibility and Control (AVC) as an end-to-end solution, which gives a complete visibility of applications in the network and allows the administrator to take some action on the same. -
RADIO RESOURCE MANAGEMENT
Cisco's Radio Resource Management (abbreviated RRM) allows Cisco's Unified WLAN Architecture to continuously analyse the existing RF environments, automatically adjusting each AP's power and channel configurations to help mitigate things such as co-channel interference and signal coverage problems. RRM reduces the need to perform exhaustive site surveys, increases system capacity and provides automated self-healing functionality to compensate for RF dead zones and AP failures -
SECURITY
Securing the Device: Cisco Umbrella (OpenDNS), Identity PSK (iPSK), IP and DNS ACLs. Securing the Air: Spectrum Intelligence, Wireless Intrusion Detection (WIDS). Securing the Network: 802.1x on AP, AAA profiling and policy -
PEACE OF MIND
Limited lifetime hardware warranty
- Cisco Aironet 1852I - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External - indoor
- Localisation
- Belgium, Bahrain, Lebanon, Oman, Saudi Arabia, United Arab Emirates, Bulgaria, Czech Republic, Estonia, Lithuania, South Africa, Iceland, Romania, Sri Lanka, Luxembourg, Hungary, Cyprus, Iraq, Ghana, Kenya, Nigeria, Liechtenstein, Gibraltar, Malta, Monaco, Croatia, Slovakia, Slovenia, Latvia, Libya, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Spain, Sweden, Switzerland, United Kingdom, Greece, Turkey, Ireland, Serbia, Montenegro, Bosnia and Herzegovina
- RAM
- 1 GB
- Flash Memory
- 256 MB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 5.0)
- Frequency Band
- 2.4 GHz, 5 GHz
- Power Over Ethernet (PoE) Supported
- PoE+
- Power
- AC 120/230 V (50 - 60 Hz)
- 21.08 cm x 21.08 cm x 50.8 cm
- 1.41 kg
- Ruggedized Design
- Indoor
- 21.08 cm
- 21.08 cm
- 50.8 cm
- 1.41 kg
- Localisation
Processor / Memory / Storage
- RAM
- 1 GB
- Flash Memory
- 256 MB
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1.7 Gbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Status
- DFS support, Wi-Fi Multimedia (WMM) support, Link Aggregation Control Protocol (LACP), Maximum Ratio Combining (MRC), 4T4R MIMO technology, 802.1x authentication, radio resource management (RRM), cyclic shift diversity (CSD), MU-MIMO technology, beamforming technology
- Encryption Algorithm
- AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2
- Authentication Method
- MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac (draft 5.0)
Aerial
- Antenna
- Internal
- Directivity
- Omni-directional
- Gain Level
- 5 dBi
- 1 x 1000Base-T (PoE+) - RJ-45 , 1 x console - RJ-45 , 1 x USB 2.0 - Type A , 1 x 1000Base-T - RJ-45
- VCCI, ICES-003, FCC Part 15.247, RSS-210, RSS-102, UL 2043, AES, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, EN50155, EMI, Directive 93/42/EEC, EN 300 328, FCC OET Bulletin 65c, TLS, EN 301 489-1, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
- PoE+
- Power Device
- External power adapter
- Voltage Required
- 20.9 watt
- -20 °C
- 50 °C
- 10 - 90% (non-condensing)
