Cisco Aironet 1815W Series Access Point
Quicklinx: F0QWWS00 Mfr#: AIR-AP1815W-E-K9
  • IEEE 802.11n
The Cisco Aironet 1815w access point offers a compact, wall plate mountable access point, ideal for hospitality, cruise ships, residential halls, or other multiple-dwelling-unit deployments. Packing 802.11ac Wave 2 wireless standards support and Gigabit Ethernet wired connectivity into a sleek device, the 1815w is built to take full advantage of existing cabling infrastructure while blending into the visual footprint. This combination provides high performance while reducing total cost of ownership.
  • MU-MIMO
    802.11ac Wave 2 with 2x2:2 MIMO technology uses two spatial streams when operating in SU-MIMO or MU-MIMO mode, offering 867 Mbps rates for more capacity and reliability than competing access points
  • APPLICATION VISIBILITY AND CONTROL
    Network Based Application Recognition (NBAR) deep-packet inspection technology provides application-aware control on a wireless network and enhances manageability and productivity. It also extends Cisco's Application Visibility and Control (AVC) as an end-to-end solution, which gives a complete visibility of applications in the network and allows the administrator to take some action on the same
  • RADIO RESOURCE MANAGEMENT
    Cisco's Radio Resource Management (abbreviated RRM) allows Cisco's Unified WLAN Architecture to continuously analyse the existing RF environments, automatically adjusting each AP's power and channel configurations to help mitigate things such as co-channel interference and signal coverage problems. RRM reduces the need to perform exhaustive site surveys, increases system capacity and provides automated self-healing functionality to compensate for RF dead zones and AP failures
  • SECURITY
    Securing the Device: Cisco Umbrella (OpenDNS), Identity PSK (iPSK), IP and DNS ACLs. Securing the Air: Spectrum Intelligence, Wireless Intrusion Detection (WIDS). Securing the Network: 802.1x on AP, AAA profiling and policy
  • PEACE OF MIND
    1-year limited hardware warranty
Cisco Aironet 1815W - radio access point - Bluetooth, Wi-Fi 5
Radio access point
In-wall mountable
710 MHz
RAM
1 GB
Flash Memory
256 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.1, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Mounting brackets, Torx security screw
Power Over Ethernet (PoE) Supported
PoE
8.9 cm x 14 cm x 3.15 cm
280 g
Radio access point
8.9 cm
14 cm
3.15 cm
280 g
Processor / Memory / Storage
Processors Installed
710 MHz
RAM
1 GB
Flash Memory
256 MB
In-wall mountable
Wireless
Data Transfer Rate
1 Gbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Port status, Boot State, error, status
VLAN support, Wi-Fi Multimedia (WMM) support, 2T2R MIMO technology, Maximum Ratio Combining (MRC), 802.1x authentication, cyclic shift diversity (CSD), MU-MIMO technology, WPA encryption, packet aggregation A-MPDU, packet aggregation A-MSDU, SU-MIMO technology, dual band, Dynamic Frequency Selection (DFS)
Encryption Algorithm
AES, TLS, PEAP, TTLS, WPA, WPA2
Authentication Method
RADIUS, MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.3at, Bluetooth 4.1, IEEE 802.11r, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
2 x 1000Base-T (PoE) - RJ-45 ¦ 1 x console - RJ-45 ¦ 1 x pass-through - RJ-45 ¦ 2 x 1000Base-T - RJ-45
VCCI, ICES-003, FCC Part 15.247, RSS-102, UL 2043, AES, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, FCC Part 15.407, ARIB STD-T66, ARIB STD-T71, EN 300 328, FCC OET Bulletin 65c, EN 301 489-1, RSS-247, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
PoE
8.5 watt
Limited warranty - advance hardware replacement - lifetime - response time: 10 days
10 - 90% (non-condensing)
