Cisco Aironet 1130AG Series Access Point
Quicklinx: 42KZWS00 Mfr#: AIR-AP1131AG-E-K9
  • Wi-Fi CERTIFIED
The Cisco Aironet 1130AG Series Access Point incorporates the next generation of Cisco Aironet radio innovation. Two high-performing radios provide simultaneous support for 802.11a and 802.11g standards, delivering 108 Mbps data rates in the 5 and 2.4 GHz bands to distances surpassing that of previous-generation radios. Operating on 15 nonoverlapping channels today, and 26 nonoverlapping channels with a future firmware release (channel support will depend on country regulations), the Cisco Aironet 1130AG Series avoids interference in congested airspace, simplifying the deployment of high-capacity networks. For smooth migration, the Cisco Aironet 1130AG Series takes full advantage of the dual-band capabilities of today's WLAN clients, while providing full backward compatibility for legacy 802.11b clients.
Cisco Aironet 1130AG Series IEEE 802.11a/b/g access points provide high-capacity, high-security, enterprise-class features in an unobtrusive, office-class design, delivering WLAN access with the lowest total cost of ownership. With high-performing dual IEEE 802.11a and 802.11g radios, the Cisco Aironet 1130AG Series provides a combined capacity of up to 108 Mbps to meet the needs of growing WLANs. Hardware-assisted Advanced Encryption Standard (AES) or temporal key integrity protocol (TKIP) encryption provides uncompromised support for interoperable IEEE 802.11i, Wi-Fi Protected Access 2 (WPA2) or WPA security. Supporting Cisco IOS Software, the Cisco Aironet 1130AG Series is a component of the Cisco Structured Wireless-Aware Network (SWAN) framework, a comprehensive framework that delivers an integrated, end-to-end wired and wireless network. Using the radio and network management features of the Cisco SWAN framework for simplified deployment, along with built-in omnidirectional antennas that provide robust and predictable WLAN coverage for offices and similar RF environments, the competitively priced Cisco Aironet 1130AG Series is ready to install and easy to manage, reducing the cost of deployment and ongoing maintenance. The Cisco Aironet 1130AG Series Access Point incorporates the next generation of Cisco Aironet radio innovation. Two high-performing radios provide simultaneous support for 802.11a and 802.11g standards, delivering 108 Mbps data rates in the 5 and 2.4 GHz bands to distances surpassing that of previous-generation radios. Operating on 15 nonoverlapping channels today, and 26 nonoverlapping channels with a future firmware release (channel support will depend on country regulations), the Cisco Aironet 1130AG Series avoids interference in congested airspace, simplifying the deployment of high-capacity networks. For smooth migration, the Cisco Aironet 1130AG Series takes full advantage of the dual-band capabilities of today's WLAN clients, while providing full backward compatibility for legacy 802.11b clients.
Cisco Aironet 1131AG - radio access point - Wi-Fi
Radio access point
External
RAM
32 MB
Flash Memory
16 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g
Power Over Ethernet (PoE) Supported
PoE
19.1 cm x 3.3 cm x 19.1 cm
0.7 kg
1-year warranty
Radio access point
19.1 cm
3.3 cm
19.1 cm
0.7 kg
Processor / Memory / Storage
RAM
32 MB
Flash Memory
16 MB
External
Wireless
Data Transfer Rate
54 Mbps
Line Coding Format
CCK, OFDM
Spread Spectrum Method
OFDM
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS
Max Range Indoors
137 m
Max Range Open Space
290 m
Status Indicators
Active, error, status
Uplink, auto-sensing per device, BOOTP support
Encryption Algorithm
LEAP, AES, 128-bit WEP, 40-bit WEP, TLS, PEAP, TKIP, WPA, WPA2, AES-CCMP
Authentication Method
Secure Shell (SSH), MS-CHAP
IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
Aerial
Antenna
Internal
Antenna Qty
2
Directivity
Omni-directional
1 x 100Base-TX (PoE) - RJ-45
ETSI, VCCI, EN 60950, ICES-003, IEC 60950, UL 60950, CSA 22.2 No. 60950, FCC Part 15.247, AS/NZS 4771, RSS-210, RSS-102, AS/NZS 3548, UL 2043, EN 300 328, EN 301 489-1, EN 301 489-17
PoE
External power adapter
12.2 Watt
Limited warranty - 1 year
10 - 90%
