Cisco 8U CME Base CUE+Phone FL
Quicklinx: 781FWS00 Mfr#: UC520-8U-4FXO-K
Cisco Unified Communications 500 Series for Small Business, a critical part of the Cisco Smart Business Communications System, is a unified communications solution for small businesses that provides voice, data, voicemail, Automated Attendant, video, security, and wireless capabilities while integrating with existing desktop applications such as calendar, e-mail, and customer relationship management (CRM) programs. This easy-to-manage platform uses business-class, proven unified communications technologies to full advantage and supports flexible deployment models based on your needs - a wide array of IP phones, public switched telephone network (PSTN) interfaces, and Internet connectivity.
Cisco Unified Communications 520 for Small Business - VoIP gateway
VoIP gateway
Licence Qty
8 users
External
Ethernet, Fast Ethernet
VoIP Protocols
H.323, SCCP, SIP
Telephony Interfaces
4 phone (FXS), 4 line (FXO)
Power Over Ethernet (PoE) Supported
PoE
26.7 cm x 28 cm x 6.7 cm
3.6 kg
1-year warranty
VoIP gateway
Installed Modules Qty (Max)
0 (1)
26.7 cm
28 cm
6.7 cm
3.6 kg
External
Wired
Switching Protocol
Ethernet
Remote Management Protocol
SNMP
Firewall protection, MAC address filtering
Encryption Algorithm
LEAP, PEAP, TKIP, WPA, WPA2
Authentication Method
RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
IEEE 802.3af, IEEE 802.1x
IP Telephony
VoIP Protocols
H.323, SCCP, SIP
Voice Codecs
G.711, G.729a
IP Telephony Features
Call waiting, call hold, call transfer
Expansion Slots
1 (total) / 1 (free) x VIC
4 x modem - RJ-11 , 4 x modem - RJ-11 , 8 x 100Base-TX (PoE) - RJ-45 , 1 x 100Base-TX - RJ-45 (WAN) , 1 x 100Base-TX - RJ-45 , 1 x audio , 1 x management
CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN50082-1, CSA 22.2 No. 60950, AS/NZS 60950-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, FCC Part 15, EN 61000-4-5, EN 61000-6-2, EN 61000-4-11, EN 61000-4-8, UL 60950-1, IEC 60950-1, EN 60950-1, EN 300 386
PoE
External power adapter
Limited warranty - 1 year
10 - 85%
