Cisco 890 series integrated services router is fixed-configuration routers that provide collaborative business solutions for secure voice and data communications to enterprise small branch offices. It is designed to deliver secure broadband, Metro Ethernet, wireless LAN (WLAN) connectivity, and business continuity. The routers also come with powerful management tools, such as the web-based Cisco configuration professional configuration management tool, which simplifies setup and deployment. Centralized management capabilities give network managers visibility and control of the network configurations at the remote site.
Secure network connectivity
Cisco 890 series router delivers high performance with integrated security and threat defense. Network security has become a fundamental building block of any network, and Cisco routers play an important role in embedding security at the customer's access edge. -
Metro Ethernet connectivity
Cisco 890 series router is ideal for service provider deployments as Metro Ethernet customer premises equipment (CPE). The routers also provide failover protection and load balancing. The 8-port managed switch provides enough LAN ports for connecting multiple devices. The Cisco 890 Series provides significant value to customers by simplifying deployment of Ethernet WAN services with end-to-end OA&M, service-level agreement (SLA) monitoring and verification, and configuration management, resulting in increased operational efficiency and reduced operating expenses (OpEx). -
High availability
Cisco 890 series router enables customers to deliver high-performance, high-availability, mission-critical business applications. These capabilities include Virtual Router Redundancy Protocol (VRRP), Hot Standby Router Protocol (HSRP), MultigroupHSRP (MHSRP), and dial backup with external modem through a virtual auxiliary port. Cisco 890 series router is integrated with ISDN BRI, a V.92 analog modem, or a Gigabit Ethernet port for a secondary WAN backup connection. If the primary Ethernet-access WAN is disconnected, the router detects this failure and fails over to the secondary backup WAN. -
Integrated wireless LAN capability
The Cisco 890 series is ideal for enterprise small branch offices and small businesses that need to be connected to larger enterprise networks. These routers help extend corporate networks to secure remote sites while giving users access to the same applications found in a corporate office. They provide increased reliability for diversity of wireless data, voice, and video applications. When users require wireless LAN (WLAN) access, visibility and control of network security are even more critical at the remote site. The Cisco 890 series meets this need with a single device that combines integrated 802.11 a/g/n capabilities with security features such as Wi-Fi Protected Access (WPA), including authentication with IEEE 802.1X with Cisco Extensible Authentication Protocol (LEAP) and Protected EAP (PEAP), and encryption with WPA Temporal Key Integrity Protocol (TKIP).
- Cisco 897VA Gigabit Ethernet Security Router with VDSL/ADSL2+ and Wireless - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 8-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- VDSL, ADSL2+
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- Frequency Band
- 2.4 GHz / 5 GHz
- L2TP, RSVP, IPSec, FTP, DHCP, DNS, L2TPv3
- Routing Protocol
- OSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, VRRP, NHRP, IGMPv3, GRE, policy-based routing (PBR), WCCP, Bidirectional Forwarding Detection (BFD)
- Remote Management Protocol
- Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI
- Firewall protection, auto-sensing per device, DHCP support, NAT support, MDI/MDI-X switch, VLAN support, auto-uplink (auto MDI/MDI-X), DiffServ support, MAC address filtering, Broadcast Storm Control, IPv6 support, IPS, LLQ, CBWFQ, WFQ, MIMO technology, STP support, VRRP support, WMM support, ACL support, QoS, LFI, DMVPN, DHCP server, VRF-Lite, DNS proxy, CleanAir technology, BFD, DHCP relay, 2T3R MIMO technology, DHCP client, HSRP support, Ingress Layer 2 MAC ACLs, CAC, FNF
- IEEE 802.1D, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n (draft 2.0)
- Power
- AC 120/230 V (50/60 Hz)
- 32.3 cm x 24.8 cm x 4.45 cm
- 1-year warranty
- Wireless router - 8-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Routing Protocol
- Encryption Algorithm
- LEAP, Triple DES, MD5, AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2, PKI, 128-bit AES, 192-bit AES, 256-bit AES, WEP
- Authentication Method
- RADIUS, TACACS+, Extensible Authentication Protocol (EAP), EAP-FAST
- IEEE 802.1D, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n (draft 2.0), CISPR 24, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, CISPR 22, EN50082-1, EN 61000-6-1, AES, FCC CFR47 Part 15, VCCI V-3, ICES-003 issue 4 Class B, ICES-003 issue 4 Class A
- RAM
- 512 MB (installed) / 1 GB (max)
- Flash Memory
- 256 MB (installed) / 256 MB (max)
- Status Indicators
- Port status, power
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- VDSL, ADSL2+
- Protocols & Specifications
- ITU G.991.2 (G.shdsl), ITU G.992.1 (G.DMT) Annex A
- LAN: 8 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ , USB: 1 x 4 pin USB Type A , WAN: 1 x SFP (mini-GBIC)
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Directivity
- Omni-directional
- Power Device
- External power adapter - 60 Watt
- Voltage Required
- OS Provided
- Cisco IOS Advanced IP services
- 32.3 cm
- 24.8 cm
- 4.45 cm
- Limited warranty - advance parts replacement - 1 year - response time: 10 days
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
