Cisco 892FSP 1 GE and 1GE/SFP High Perf Security Router
Quicklinx: DB0QWS00 Mfr#: C892FSP-K9
£1,156.27 ex VAT
£1,387.52 inc VAT
Cisco 890 series integrated services router combines Internet access, comprehensive security, and wireless services in a single, secure device that is easy to deploy and manage. The best-in-class Cisco 890 series architecture has been specifically designed to deliver high performance with concurrent services, business continuity, and investment protection for enterprise small branch offices and service provider managed services applications.
Cisco 890 series integrated services router is a fixed-configuration router that provides collaborative business solutions for secure voice and data communications to enterprise small branch offices. It is designed to deliver secure broadband, Metro Ethernet, Wireless LAN (WLAN) connectivity, and business continuity. The router also comes with powerful management tools, such as the web-based Cisco configuration professional configuration management tool, which simplifies setup and deployment. Centralized management capabilities give network managers visibility and control of the network configurations at the remote site.
Cisco 892FSP - router - desktop
Router - 8-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Connection / user qty: 50
Network / Transport Protocol
L2TP, IPSec
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, VRRP, NHRP, GRE, WCCP, Bidirectional Forwarding Detection (BFD)
Remote Management Protocol
Telnet, SNMP 3, HTTP, SSH, CLI
NAT support, VPN support, VLAN support, IGMP snooping, DiffServ support, MAC address filtering, IPv6 support, IPS, LLQ, CBWFQ, WFQ, STP support, ACL support, QoS, LFI, RADIUS support, DHCP server, DNS proxy, DHCP relay, DHCP client, VRF, CoS
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x, IEEE 802.3ah, IEEE 802.1ag
32.3 cm x 24.8 cm x 4.4 cm
1-year warranty
Enclosure Type
Desktop
Wired
L2TP, IPSec
Routing Protocol
Authentication Method
RADIUS, TACACS+
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x, IEEE 802.3ah, IEEE 802.1ag, VCCI-II, EN55024, CSA 22.2 No. 60950, EN55022 Class B, AS/NZ 3548 Class B, AS/NZS 60950-1, CS-03, EN 60555-2, UL 60950-1, IEC 60950-1
RAM
512 MB (installed) / 1 GB (max)
Flash Memory
256 MB (installed) / 256 MB (max)
Status Indicators
Port status, power
LAN: 8 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x SFP (mini-GBIC) , WAN: 2 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x auxiliary - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , Management: 1 x console - RJ-45
External power adapter - 60 Watt
1 x network cable - 1.8 m
OS Provided
Cisco IOS Advanced IP services
32.3 cm
24.8 cm
4.4 cm
Limited warranty - 1 year
10 - 85% (non-condensing)
Accessories (1)
Get the most from your Router
DB0Q Cisco 1000BASE-T SFP Transceiver In Stock £180.57
Other bundles (1)
DB0Q Cisco AC Power Cord In Stock £40.73
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Brand: Cisco
Price Range Ex VAT: £1000 - £1500
