Cisco 890 Series Integrated Services Routers (ISRs) are fixed-configuration routers that provide collaborative business solutions for secure voice and data communications to enterprise small branch offices. They are designed to deliver secure broadband, Metro Ethernet, wireless LAN (WLAN) connectivity, and business continuity. The routers also come with powerful management tools, such as the web-based Cisco Configuration Professional configuration management tool, which simplifies setup and deployment. Centralized management capabilities give network managers visibility and control of the network configurations at the remote site.
PORT COUNT
8-port managed Gigabit Ethernet switch (4 ports PoE capable with 125W power supply adapter) -
CONNECTIVITY
Integrated 802.11n access point supports both autonomous and unified modes -
SECURITY
VPN; firewall support for highly secure remote-access client connectivity -
PERFORMANCE
Business router designed to run multiple services simultaneously with no performance degradation -
PEACE OF MIND
1-year limited hardware warranty with 10-day advanced replacement
- Cisco 891F - router - ISDN/Mdm - desktop, rack-mountable
- Router - ISDN / analogue modem combo - 8-port switch (integrated)
- Enclosure Type
- Desktop, rack-mountable - 1U
- Data Link Protocol
- Capacity
- IPSec VPN tunnels: 50
- L2TP, RSVP, ICMP/IP, IPSec, FTP, DHCP, DNS, L2TPv3, DDNS, RTP
- Routing Protocol
- OSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, VRRP, NHRP, GRE, OSPFv3, policy-based routing (PBR), BGP-4+, WCCP, Bidirectional Forwarding Detection (BFD)
- Remote Management Protocol
- Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI
- Firewall protection, NAT support, PoE, auto-uplink (auto MDI/MDI-X), IGMP snooping, traffic shaping, dynamic DNS server, DiffServ support, MAC address filtering, IPv6 support, High Availability, IPS, LLQ, CBWFQ, WFQ, WRED, STP support, ACL support, QoS, LFI, DMVPN, DHCP server, VRF-Lite, DNS proxy, fanless, DHCP relay, DHCP client, CoS, FNF, security lock slot (cable lock sold separately), DSCP support, Storm Control
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.3af, IEEE 802.1x
- Power
- AC 120/230 V (50/60 Hz)
- 32.5 cm x 24.9 cm x 4.4 cm
- 2.5 kg
- 1-year warranty
- Router - 8-port switch (integrated)
- Enclosure Type
- Connectivity Technology
- Wired
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, SSL, PKI, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, TACACS+
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.3af, IEEE 802.1x, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN50082-1, EN 61000-6-1, KN22, EN 300386
- RAM
- 512 MB (installed) / 1 GB (max)
- Flash Memory
- 256 MB
Communications
- Protocols & Specifications
- ITU V.92
- Management: 1 x console - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , LAN: 4 x 10Base-T/100Base-TX/1000Base-T (PoE) - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x SFP (mini-GBIC) , WAN: 1 x BRI ST , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x modem - RJ-11
- Power Device
- External power adapter - 60 Watt
- Voltage Required
- OS Provided
- Cisco IOS Advanced IP services
- 32.5 cm
- 24.9 cm
- 4.4 cm
- 2.5 kg
- Limited warranty - advance parts replacement - 1 year - response time: 10 days
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
Accessories (1)
Get the most from your Router
Cisco 1000BASE-T SFP Transceiver | In Stock | £181.04 |
Other bundles (1)
Cisco AC Power Cord | In Stock | £40.73 |
