Cisco 891 Gigabit Ethernet Security Router
Quicklinx: 88FXWS00 Mfr#: CISCO891-K9
Cisco 890 series integrated services router is designed to deliver highly secure broadband, Metro Ethernet, wireless LAN connectivity, and business continuity for enterprise small branch offices. This fixed-configuration router also comes with powerful management tools, such as the web-based Cisco configuration professional, which simplifies setup and deployment.
Cisco 891 - router - desktop
Router - 8-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
3
Ethernet, Fast Ethernet
IPSec VPN tunnels: 50
Network / Transport Protocol
L2TP, IPSec, FTP, DHCP, DNS, L2TPv3, DDNS
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, VRRP, NHRP, PIM-SM, GRE
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS, SSH
NAT support, VPN support, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, traffic shaping, SPI, content filtering, DiffServ support, MAC address filtering, IPv6 support, High Availability, IPS, URL filtering, Stateful Failover, CBWFQ, WFQ, STP support, ACL support, QoS, LFI, DMVPN, WAN failover, DHCP server, VRF-Lite, DNS proxy, BFD
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x
32.5 cm x 24.9 cm x 4.4 cm
2.5 kg
Enclosure Type
Desktop
Wired
Routing Protocol
Encryption Algorithm
LEAP, DES, Triple DES, SSL, PEAP, TKIP, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, TACACS+
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN50082-1, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, AS/NZ 3548 Class B, EN 60555-2, FCC CFR47 Part 15, FCC CFR47 Part 15 B, VCCI V-3, EN 300 386
RAM
512 MB (installed) / 768 MB (max)
Flash Memory
256 MB (installed) / 256 MB (max)
Status Indicators
Port status, power
Communications
Modem (analogue)
Protocols & Specifications
ITU V.92
LAN: 8 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x auxiliary - RJ-45 , Peripheral: 2 x USB 2.0 - 4 pin USB Type A , WAN: 1 x modem
External power adapter - 60 Watt
OS Provided
Cisco IOS Advanced IP services
32.5 cm
24.9 cm
4.4 cm
2.5 kg
10 - 85% (non-condensing)
