The Cisco 888 Integrated Services Routers combine Internet access and security services onto a single, secure device. This router offers broadband speeds and simplified management to small businesses, and enterprise small branch and teleworkers.
- Cisco 888 G.SHDSL Router with ISDN backup - router - DSL modem - desktop
- Router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet
- Capacity
- IPSec VPN tunnels: 20
- L2TP, IPSec, PPPoE, PPPoA, FTP, DHCP, DNS, L2TPv3, DDNS
- Routing Protocol
- OSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, VRRP, NHRP, PIM-SM, GRE
- Remote Management Protocol
- Telnet, SNMP 3, HTTP, HTTPS, SSH
- NAT support, VPN support, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, traffic shaping, SPI, content filtering, DiffServ support, MAC address filtering, IPv6 support, High Availability, IPS, URL filtering, Stateful Failover, CBWFQ, WFQ, STP support, ACL support, QoS, LFI, DMVPN, WAN failover, DHCP server, VRF-Lite, DNS proxy, BFD
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x
- Power
- AC 120/230 V (50/60 Hz)
- 32.5 cm x 24.9 cm x 4.4 cm
- 2.5 kg
- Router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Capacity
- Routing Protocol
- Encryption Algorithm
- LEAP, DES, Triple DES, SSL, PEAP, TKIP, PKI, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, TACACS+
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN50082-1, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, AS/NZ 3548 Class B, EN 60555-2, FCC CFR47 Part 15, FCC CFR47 Part 15 B, VCCI V-3, EN 300 386
- RAM
- 256 MB (installed) / 768 MB (max)
- Flash Memory
- 128 MB
- Status Indicators
- Port status, power
Communications
- DSL modem
- Protocols & Specifications
- ITU G.991.2 (G.shdsl)
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x SHDSL , USB: 1 x 4 pin USB Type A , WAN: 1 x BRI ST - RJ-45
- Power Device
- External power adapter - 60 Watt
- Voltage Required
- OS Provided
- Cisco IOS Advanced Security
- 32.5 cm
- 24.9 cm
- 4.4 cm
- 2.5 kg
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
