Cisco 887VAG 4G LTE 2.0 ISR DSL/WWAN Desktop Router
Quicklinx: BHX5WS00 Mfr#: C887VAG-4G-GA-K9
The Cisco 880G Series 4G LTE 2.0 ISRs are fixed-configuration routers that provide collaborative business solutions for secure voice and data communications to enterprise small branch offices. They provide persistent, reliable LTE connectivity with fallback and transparent handoff to earlier technologies. The routers are designed to deliver secure broadband, Metro Ethernet or any xDSL variants, wireless WAN (WWAN) connectivity, and business continuity.
  • Robust connectivity
    Equipped with both Ethernet and Fast Ethernet capabilities, the Cisco 887VAG 4G LTE 2.0 ISR ensures reliable, high-speed wired connections for a variety of network needs.
  • Versatile mobile broadband
    Supporting a wide range of cellular protocols including LTE, HSPA+, and GSM, this router offers extensive coverage and flexibility for mobile broadband connectivity.
  • Comprehensive security
    With AES, DES, and Triple DES encryption algorithms, the device provides robust security measures to protect sensitive data transmitted over the network.
  • Flexible management options
    Featuring support for CLI, HTTP, SNMP, and Telnet, the router allows for versatile remote management, enabling efficient network administration and monitoring.
Cisco 887VAG 4G LTE 2.0 ISR - router - DSL/WWAN - desktop
Router - DSL modem / wireless cellular modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, VDSL2
Mobile Communication Protocol
GSM, GPRS, UMTS, EDGE, HSPA+, LTE
WAN Ports Qty
1
Ethernet, Fast Ethernet
Remote Management Protocol
SNMP, Telnet, HTTP, CLI
32.5 cm x 26.4 cm x 4.8 cm
2.54 kg
Australia, Europe
1-year warranty
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
Encryption Algorithm
DES, Triple DES, AES
CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, EN 61000-4-11, UL 60950-1 Second Edition, BSMI CNS 13438, VCCI V-3, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, AS/NZS CISPR 22, EN 301 489-7, EN 301 489-1, EN 300 386, EN 301 489-24, EN 301 511
RAM
1 GB (installed) / 1 GB (max)
Flash Memory
Built-in Devices
GPS
Communications
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ , Management: 1 x console - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , Management: 1 x mini-USB Type B , Antenna: 1 x SMA
Expansion Slots
2 (total) / 2 (free) x SIM
Aerial
Aerial
External detachable
Antenna Qty
2
Australia, Europe
32.5 cm
26.4 cm
4.8 cm
2.54 kg
Limited warranty - 1 year
