Cisco 887VAG 4G LTE 2.0 ISR DSL/WWAN Desktop Router
Quicklinx: BHX5WS00 Mfr#: C887VAG-4G-GA-K9
The Cisco 880G Series 4G LTE 2.0 ISRs are fixed-configuration routers that provide collaborative business solutions for secure voice and data communications to enterprise small branch offices. They provide persistent, reliable LTE connectivity with fallback and transparent handoff to earlier technologies. The routers are designed to deliver secure broadband, Metro Ethernet or any xDSL variants, wireless WAN (WWAN) connectivity, and business continuity.
Cisco 887VAG 4G LTE 2.0 ISR - router - DSL/WWAN - desktop
Router - DSL modem / wireless cellular modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, VDSL2
Cellular Protocol
GSM, GPRS, UMTS, EDGE, HSPA+, LTE
WAN Ports Qty
1
Ethernet, Fast Ethernet
Remote Management Protocol
SNMP, Telnet, HTTP, CLI
32.5 cm x 26.4 cm x 4.8 cm
2.54 kg
Australia, Europe
1-year warranty
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
Encryption Algorithm
DES, Triple DES, AES
CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN 61000-6-1, EN 301.489.1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, EN 61000-4-11, EN300-386, UL 60950-1 Second Edition, EN 301.489.7, EN 301.489.24, EN 301.511, BSMI CNS 13438, VCCI V-3, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, AS/NZS CISPR 22
RAM
1 GB (installed) / 1 GB (max)
Flash Memory
Built-in Devices
GPS
Communications
Cellular Protocol
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ , Management: 1 x console - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , Management: 1 x mini-USB Type B , Antenna: 1 x SMA
Expansion Slots
2 (total) / 2 (free) x SIM
Aerial
Aerial
External detachable
Antenna Qty
2
Australia, Europe
32.5 cm
26.4 cm
4.8 cm
2.54 kg
Limited warranty - 1 year
