Cisco 880 Series Integrated Services Routers
Quicklinx: C0XMWS00 Mfr#: C887VA-K9
Cisco 880 series integrated services router is fixed-configuration router that provides collaborative business solutions for secure voice and data communication to small businesses and enterprise teleworkers. They offer concurrent broadband services over third-generation (3G), Metro Ethernet, and multiple DSL technologies to provide business continuity. Wireless 802.11n and 3G offer LAN and WAN mobility. The routers provide the performance required for concurrent services, including firewall, intrusion prevention, content filtering, and encryption for VPNs; and quality-of-service (QoS) features for optimizing voice and video applications. In addition, the web-based Cisco configuration professional configuration tool simplifies setup and deployment. Centralized management capabilities give network managers visibility and control of the network configurations at the remote site.
The Cisco 880 series is ideal for small branch offices and teleworkers who need to be connected to larger enterprise networks as well as small businesses. These routers help extend corporate networks to secure remote sites while giving users access to the same applications found in a corporate office. This access applies to both data and voice applications. When users require WLAN access, visibility and control of network security are even more critical at the remote site. The Cisco 880 series meets this need with a single device that combines integrated 802.11g/n capabilities with security features.
  • Increased performance to run concurrent services
    Cisco 880 series router performance allows customers to take advantage of broadband network speeds while running secure, concurrent data, voice, video, and wireless services.
  • Enhanced security
    An integrated stateful and application inspection firewall provides network perimeter security. High-speed IPsec 3DES and AES encryption offers data privacy over the Internet.
  • Four-port 10/100 Mbps managed switch
    The Cisco 880 series allows for connection of multiple devices in a small office, with the ability to designate a port as the network edge. VLANs allow for secure segmentation of network resources.
  • CON/AUX port
    A single dual-purpose port provides direct connection to a console or external modem for management or backup access points.
  • Real-time clock
    A built-in real-time clock maintains an accurate date and time for applications that require an accurate time stamp, such as logging and digital certificates.
Cisco 887 VDSL/ADSL over POTS Multi-mode Router - router - DSL modem - desktop
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, VDSL2
WAN Ports Qty
2
Ethernet, Fast Ethernet
IPSec VPN tunnels: 20
Network / Transport Protocol
L2TP, DHCP
Routing Protocol
RIP-1, RIP-2, HSRP, VRRP, GRE, policy-based routing (PBR)
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI
NAT support, auto-uplink (auto MDI/MDI-X), MAC address filtering, LLQ, CBWFQ, WFQ, STP support, ACL support, QoS, DHCP server, DNS proxy, fanless, DHCP relay, DHCP client, CoS
IEEE 802.1D, IEEE 802.1Q
32.5 cm x 24.9 cm x 4.4 cm
2.5 kg
1-year warranty
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
L2TP, DHCP
Routing Protocol
Encryption Algorithm
DES, Triple DES, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, TACACS+
IEEE 802.1D, IEEE 802.1Q, CISPR 24, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN50082-1, EN55022 Class B, EN 61000-6-1, EN 60555-2, FCC CFR47 Part 15, FCC CFR47 Part 15 B, VCCI V-3, KN22, EN 300386
RAM
256 MB (installed) / 768 MB (max)
Flash Memory
256 MB (installed) / 256 MB (max)
Status Indicators
Port status, power
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.994.1 (G.hs), ITU G.992.1 (G.DMT) Annex A, ITU G.992.3 Annex A, ITU G.993.2, ITU G.992.5 Annex A
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x ADSL2+ , USB: 1 x 4 pin USB Type A , WAN: 1 x VDSL2
External power adapter - 60 Watt
OS Provided
Cisco IOS Advanced Security
32.5 cm
24.9 cm
4.4 cm
2.5 kg
Limited warranty - 1 year
10 - 85% (non-condensing)
C0XM C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
C0XM C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
