Cisco 877 Wireless ADSL Router
Quicklinx: 5KV2WS00 Mfr#: CISCO877W-G-EK9
  • Wi-Fi CERTIFIED
Cisco 870 Series of integrated services routers are fixed-configuration routers that support multiple types of DSL technologies, broadband cable, and Metro Ethernet connections in small offices. They provide the performance needed to run concurrent services, including firewall, intrusion prevention, and encryption for VPNs; optional 802.11b/g for WLAN networking; and quality of service (QoS) features for optimizing voice and video applications. In addition, the Cisco Router and Security Device Manager (SDM) Web-based configuration tool simplifies setup and deployment, and centralized management capabilities give network managers visibility and control of the network configurations at the remote site.
Cisco 877W - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
VPN tunnels: 10
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA
Routing Protocol
RIP-1, RIP-2
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS
Firewall protection, auto-sensing per device, DHCP support, NAT support, VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), SPI, manageable, MAC address filtering, IPv6 support, IPS, WMM support, ACL support, QoS, NAC
IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
26 cm x 23.2 cm x 5.1 cm
1 kg
Europe
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
VPN tunnels: 10
Routing Protocol
RIP-1, RIP-2
Encryption Algorithm
LEAP, Triple DES, MD5, AES, TLS, PEAP, TKIP, WPA, WPA2
Authentication Method
RADIUS, Radio Service Set ID (SSID), TACACS+
IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, ETSI, EN 60950, IEC 61000-3-2, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, IEC950, VCCI-II, EN55022 Class B, ICES-003 Class B, AS/NZ 3548 Class B, AS/NZS 3260, FCC Part 68, CS-03, UL 1950 Third Edition, EN 60555-2
RAM
128 MB (installed) / 256 MB (max)
Flash Memory
24 MB (installed) / 52 MB (max)
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.3 (G.DMT.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.992.1 (G.DMT) Annex B, ITU G.992.5 Annex A
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL - RJ-11 , Management: 1 x console - RJ-45
Aerial
Aerial
External detachable
Gain Level
2.2 dBi
External power adapter - 26 Watt
Europe
26 cm
23.2 cm
5.1 cm
1 kg
10 - 85%
