Cisco 867VAE Secure Router DSL Modem - Desktop, Rack-Mountable
Quicklinx: B438WS00 Mfr#: CISCO867VAE-K9
An entry level member of the Cisco Integrated Services Router Generation 2 (ISR G2) family, the Cisco 867VAE Integrated Services Router offers connectivity to teleworkers and small branches.
  • Robust connectivity
    Equipped with Ethernet, Fast Ethernet, and Gigabit Ethernet capabilities, the Cisco 867VAE Secure router ensures high-speed and reliable connections for all your networking needs. Its comprehensive interface support, including ADSL2+ and VDSL2 for WAN and a 5-port switch for LAN, makes it a versatile solution for various network configurations.
  • Enhanced security features
    The Cisco 867VAE Secure router comes with an array of security features designed to protect your network. With firewall protection, MAC address filtering, and Port Security, it safeguards your data from unauthorized access and potential threats. Additionally, the support for IPSec VPN tunnels enables secure communication channels for remote access.
  • Advanced networking capabilities
    This router supports a wide range of protocols and features to optimize your network's performance. From Class-Based Weighted Fair Queuing (CBWFQ) and Low-latency queuing (LLQ) to policy-based routing (PBR) and NetFlow, it provides the tools needed to manage traffic efficiently, ensuring smooth and reliable network operation.
Cisco 867VAE Secure - router - DSL modem - desktop, rack-mountable
Router - DSL modem - 5-port switch (integrated)
Enclosure Type
Desktop, rack-mountable - 1U
Digital Signaling Protocol
ADSL2+, VDSL2
WAN Ports Qty
2
IPSec VPN tunnels: 10
Network / Transport Protocol
IPSec, PPPoE, PPPoA, DHCP, DNS
Routing Protocol
RIP-1, RIP-2, BGP, policy-based routing (PBR)
Remote Management Protocol
SNMP 3, HTTP, HTTPS, SSH
Firewall protection, auto-uplink (auto MDI/MDI-X), MAC address filtering, IPv6 support, LLQ, CBWFQ, WFQ, DHCP server, DNS proxy, DHCP relay, Port Security, WSMA, NetFlow, DHCP client
IEEE 802.1Q, IEEE 802.3ah
20.9 cm x 19.8 cm x 3.9 cm
2.5 kg
Router - 5-port switch (integrated)
Enclosure Type
Wired
Routing Protocol
IEEE 802.1Q, IEEE 802.3ah, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EN 61000-4-3, EN 61000-4-6, AS/NZS 3548, FCC CFR47 Part 15, VCCI V-3
RAM
256 MB (installed) / 256 MB (max)
Flash Memory
56 MB
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL2+, VDSL2
Protocols & Specifications
ITU G.994.1 (G.hs), ITU G.992.3 Annex A, ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.993.2, ITU G.992.3 Annex M, ITU G.992.5 Annex A, ITU G.992.5 Annex B, ITU G.992.3 Annex B
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x ADSL2+ , USB: 1 x 4 pin USB Type A , WAN: 1 x VDSL2 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Expansion Slots
1 (total) / 1 (free) x ExpressCard
External power adapter - 60 Watt
OS Provided
Cisco IOS Advanced Security
20.9 cm
19.8 cm
3.9 cm
2.5 kg
10 - 85% (non-condensing)
B438 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
B438 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
