Cisco 8-port 10/100 PoE M.Switch w/G
Quicklinx: 75G4WS00 Mfr#: SRW208P-K9-UK
The Cisco 300 series, part of the Cisco Small Business line of network solutions is a portfolio of affordable managed switches that provides a reliable foundation for your business network. These switches deliver the features you need to improve the availability of your critical business applications, protect your sensitive information, and optimize your network bandwidth to deliver information and applications more effectively. Easy to set up and use, the Cisco 300 series provides the ideal combination of affordability and capabilities for small businesses, and helps you create a more efficient, better-connected workforce.
The Cisco 300 series is broad portfolio of fixed-configuration managed Ethernet switches. However, unlike other small business switching solutions that provide managed network capabilities only in the costliest models, all Cisco 300 series switches support the advanced security management capabilities and network features you need to support business-class data, voice, security, and wireless technologies. At the same time, these switches are simple to deploy and configure, allowing you to take advantage of the managed network services your business needs.
  • High performance and reliability
    Cisco 300 series switch has been rigorously tested to deliver the high availability and performance you expect from a Cisco switch. The solutions speed up file transfer times and improve slow, sluggish networks, while keeping your vital business applications available and preventing costly downtime. As a managed switching solution, the Cisco 300 series also gives you the flexibility to manage and prioritize high-bandwidth traffic such as voice. That means you can empower your employees with state-of-the-art communication and productivity solutions, without draining the performance of your other business applications.
  • Fast, easy setup and configuration
    Cisco 300 series switch is designed to be easy to use and manage by small businesses and the partners who serve them. The included device manager software provides an intuitive, web-based interface to simplify setup, security, and quality of service (QoS) traffic prioritization, allowing even users without IT expertise to configure the switch in minutes. Cisco also provides a Cisco FindIT network discovery utility. This utility that works through a simple toolbar on the user's web browser to discover Cisco devices in the network and display basic information, such as serial numbers and IP addresses, to aid in the configuration and deployment of Cisco Small Business products.
  • IP telephony support
    Cisco 300 series switch includes embedded QoS intelligence to prioritize delay-sensitive services such as voice and video, simplify unified communications deployments, and help ensure consistent network performance for all services. For example, automated voice VLAN capabilities let you plug any IP phone into your IP telephony network and receive an immediate dial tone. The switch automatically configures the device with the right VLAN and QoS parameters to prioritize voice traffic.
  • Network-wide automatic voice deployment
    Using a combination of CDP, LLDP-MED, Auto Smartports, and VSDP, customers can deploy an end-to-end voice network dynamically. The switch in the network automatically converge around a single voice VLAN and QoS parameters and then propagate them out to the phones on the ports where they are discovered. For example, automated voice VLAN capabilities let you plug any IP phone into your IP telephony network and receive an immediate dial tone. The switch automatically configures the device with the right VLAN and QoS parameters to prioritize voice traffic.
  • Optimal energy efficiency
    Cisco 300 series switch is designed with a variety of power-saving features across all models, providing the industry's broadest portfolio of "green" switch. This switch optimizes power use to protect the environment and reduce energy costs, without compromising performance.
Cisco Small Business SF302-08P - switch - 8 ports - Managed
Switch - 8 ports - L3 - Managed
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
8K entries
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Layer 3 switching, Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, MSTP support, TFTP support, ACL support, QoS, Jumbo Frames support, MLD snooping
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
27.9 cm x 17 cm x 4.5 cm
1.21 kg
Chinese (simplified), English, German, French, Italian, Spanish, Japanese / United Kingdom
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
PoE
8K entries
Routing Protocol
Static IPv4 routing
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
16 MB Flash
Status Indicators
Port transmission speed, system, link/activity
8 x 100Base-TX RJ-45 PoE , 1 x console DB-9 management , 2 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
External power adapter
1 x serial cable
Rack Mounting Kit
Included
MTBF
65,527 hours
UL 60950, CSA 22.2 No. 60950, FCC Part 15 A
27.9 cm
17 cm
4.5 cm
1.21 kg
Limited warranty - replacement - lifetime - response time: next business day
10 - 90% (non-condensing)
