Cisco 8-port 10/100 Managed Switch
Quicklinx: 75G2WS00 Mfr#: SRW208-K9-G5
Cisco 300 series switch delivers the ideal combination of price, performance, and capabilities in a solution designed specifically for small businesses. This broad portfolio of affordable managed switch provides a powerful foundation to support your business network.
  • High performance and reliability
    Get the high availability and performance you need to support vital business applications while reducing downtime.
  • Advanced features
    Control network traffic with advanced features such as quality of service (QoS), Layer 3 static routing, and IPv6 support.
  • Easy setup and management
    Intuitive browser-based tools, mass deployment capabilities, and consistent features across all models simplify setup and configuration.
  • An eco-friendly solution
    Switches optimize power usage for energy efficiency without compromising performance.
  • Advanced features
    Strong security features include access control lists (ACLs), guest virtual LANs (VLANs), and other advanced security features to tightly control networks. IPv6 support allows you to move up to the next generation of networking applications and operating systems without an extensive equipment upgrade. Quality of service (QoS) on all models prioritizes network traffic to keep critical network applications running at top performance.
  • Energy efficiency and design
    It support of Energy Efficient Ethernet (EEE) and reduction of energy consumption by monitoring traffic and putting links into sleep mode during quiet periods. Power-saving technology allows switch to enter sleep mode, turn off unused ports, and adjust power as needed. Fanless design on several models allows switch to run silently and unobtrusively. LEDs can be turned off to save power.
Cisco Small Business SF300-08 - switch - 8 ports - Managed
Switch - 8 ports - L3 - Managed
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
8 x 10/100
MAC Address Table Size
8K entries
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Layer 3 switching, Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, MSTP support, TFTP support, ACL support, QoS, Jumbo Frames support, MLD snooping
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
27.9 cm x 17 cm x 4.5 cm
1.16 kg
Chinese (simplified), English, German, French, Italian, Spanish, Japanese / Europe
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
8 x 10/100
8K entries
Routing Protocol
Static IPv4 routing
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
16 MB Flash
Status Indicators
Port transmission speed, system, link/activity
8 x 100Base-TX RJ-45 , 1 x console DB-9 management
External power adapter
1 x serial cable
Rack Mounting Kit
Included
MTBF
71,006 hours
UL 60950, CSA 22.2 No. 60950, FCC Part 15 A
27.9 cm
17 cm
4.5 cm
1.16 kg
Limited warranty - replacement - lifetime - response time: next business day
10 - 90% (non-condensing)
75G2 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
75G2 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.96
75G2 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.76
