Cisco 8 Line IP Phone With PoE and PC Port
Full-featured business-class IP phone
Quicklinx: 6JHBWS00 Mfr#: SPA501G
Stock Status: Clearance
Hurry, only 2 left in stock!
£35.67 ex VAT
£42.80 inc VAT
Express delivery Delivered on Tuesday
Part of the Cisco Small Business Series, the SIP-based Cisco SPA501G Basic 8-Line IP Phone has been tested to ensure comprehensive interoperability with equipment from voice over IP (VoIP) infrastructure leaders, enabling service providers to quickly roll out competitive, feature-rich services to their customers.
With hundreds of features and configurable service parameters, the Cisco SPA501G addresses the requirements of traditional business users while building on the advantages of IP telephony. Features such as easy station moves and shared line appearances (across local and geographically dispersed locations) are just some of the many advantages of the Cisco SPA501G.
  • Comprehensive interoperability and sip-based feature set
    Part of the Cisco Small Business Pro Series, the SIP- based Cisco SPA 501G Basic 8-Line IP Phone has been tested to ensure comprehensive interoperability with equipment from voice over IP (VoIP) infrastructure leaders, enabling service providers to quickly roll out competitive, feature-rich services to their customers. With hundreds of features and configurable service parameters, the Cisco SPA 501G addresses the requirements of traditional business users while building on the advantages of IP telephony. Features such as easy station moves and shared line appearances (across local and geographically dispersed locations) are just some of the many advantages of the Cisco SPA 501G.
  • Carrier-grade security, provisioning, and management
    The Cisco SPA 501G uses standard encryption protocols to perform highly secure remote provisioning and unobtrusive in-service software upgrades. Remote provisioning tools include detailed performance measurement and troubleshooting features, enabling network providers to deliver high-quality support to their subscribers. Remote provisioning also saves service providers the time and expense of managing, preloading, and reconfiguring customer premises equipment.
Cisco Small Business SPA 501G - VoIP phone
VoIP phone
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, SIP v2, SPCP
Voice Codecs
G.722, G.729a, G.711u, G.711a, G.726
Lines Supported
Multiline
Intercom
Speakerphone
Yes (digital duplex)
Voice Mail Capability
Call Services
Voice Mail, Call Waiting, Call Forwarding, Call Transfer, Call Hold
Automatic Redial
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX
Body Colour
Silver, dark grey
1-year warranty
Small Business Pro Unified Communications 320 with 4 FXO
VoIP phone
Body Colour
Silver, dark grey
Body Material
ABS plastic
Phone Features
Call Services
Key Expansion Module Max Qty
2
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
3-way
Intercom
Speakerphone
Automatic Redial
Function Buttons
Conference button, speakerphone button, transfer button, headset button, mute button, hold button, auto redial button
Programmable Buttons Qty
8
Volume Control
Ringer Control
Indicators
Voice message waiting indicator, speakerphone indicator, headset
Firmware Upgradable
Additional Functions
Pager Call, Intercom, automatic redial
Additional Features
On-hook dialling, music on hold, built-in web server, paper label insert
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP, SIP v2, SPCP
Voice Codecs
Lines Supported
Multiline
Quality of Service
IEEE 802.1Q (VLAN), Differentiated Services (DiffServ), IEEE 802.1p, Type of Service (ToS)
IP Address Assignment
DHCP
Security
256 bit AES
Power Over Ethernet (PoE) Support
Network Protocols
IP, TCP, TFTP, UDP, ICMP, ARP, HTTP, DNS, HTTPS
Network Ports Qty
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD), HD Voice
Network Features
Network Address Translation (NAT)
Phone Memory
Phone Directory Capacity
100 names & numbers
Call Log Capacity
60 numbers
Headset jack / sub-mini-phone 2.5mm
Network cable
UL, C-Tick, CB, FCC Part 15 B, A-Tick
Dimensions & Weight (Base)
21.4 cm
4.4 cm
21.2 cm
0.9 kg
Limited warranty - 1 year
Cisco Small Business Pro Unified Communications 320 with 4 FXO
6JHB C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
6JHB C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
6JHB C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.95
6JHB Cisco 32 Button Attendant Console for Cisco SPA500 Serie In Stock £50.11
6JHB C2G 2m Cat6a Shielded Patch - Blue In Stock £7.33
Brand: Cisco
Price Range Ex VAT: 0 - 50
