Cisco 7900 Transformer Power CableU
Quicklinx: 4GYWWS00 Mfr#: CP-PWR-CORD-UK=
25 In Stock
£15.26 ex VAT
£18.31 inc VAT
By using system components manufactured by Cisco, you are assured a higher level of reliability and are less likely to experience compatibility problems. Cisco testing is among the most rigorous in the industry so you can be confident that you're receiving the highest quality and dependability.
  • Efficient connectivity
    Designed for seamless power integration, this cable features a power IEC 60320 C13 connector on one end and a power BS 1363 connector on the other, ensuring reliable connectivity and power supply for your PC.
  • Durable design
    Crafted with durability in mind, this power cable is built to withstand the rigors of daily use, providing a dependable power solution for your computing needs.
Cisco - power cable - power IEC 60320 C13 to BS 1363 - 2.5 m
Power cable
Length
2.5 m
United Kingdom
Connector
Power IEC 60320 C13
Connector (Second End)
Power BS 1363 - male
Package Type
Retail
P/N: CP-PWR-CUBE-3, CP-PWR-CUBE-3=, CP-PWR-CUBE-3-RF, CP-PWR-CUBE-4, CP-PWR-CUBE-4=, CP-PWR-CUBE-4-RF, CP-PWR-CUBE-6=
Power cable
Length
2.5 m
United Kingdom
Connector
Power IEC 60320 C13
Package Type
Retail
