Cisco 48-port 10/100/ 1000 Switch
Quicklinx: 6CXPWS00 Mfr#: SGE2010P-G5
Centralize your network operations on a powerful core that's capable of handling all your data and more. Formerly Linksys Business Series, now Cisco Small Business Managed Switches, the SGE2010P Ethernet Switch allows you to securely and reliably expand the size of your high-speed gigabit network. The SGE2010P maximizes network availability by incorporating redundant stacking and power capabilities. To reduce the number of cables needed for connected devices, this managed switch supports Power over Ethernet (PoE) and 15W of power for up to 24 ports. The integrated security and authorization features prevent unauthorized access to your network's critical information, and included Quality of Service (QoS) functionality bolsters your video and voice communications.
Cisco Small Business Managed SGE2010P - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE) + 4 x shared SFP
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
8K entries
Routing Protocol
IGMPv2, IGMP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH
Auto-sensing per device, DHCP support, auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, firmware upgradable, SNTP support, ACL support, QoS, Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
44 cm x 37.5 cm x 4.4 cm
4.9 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
8K entries
Max Units In A Stack
4
Routing Protocol
IGMPv2, IGMP
Encryption Algorithm
MD5
Authentication Method
Secure Shell (SSH), RADIUS
Status Indicators
Port transmission speed, power, link OK, Unit ID, link/activity
48 x 1000Base-T RJ-45 PoE , 1 x console management , 4 x SFP (mini-GBIC)
Internal power supply
Redundant Power System (RPS) connector
1 x serial cable
Rack Mounting Kit
Included
UL 60950, CSA C22.2, FCC CFR47 Part 15
44 cm
37.5 cm
4.4 cm
4.9 kg
10 - 90%
