You use QSFP+ transceivers with networking ports used for uplinking and downlinking. For low-cost connections to switches in the same or adjacent racks, use QSFP+ transceivers with copper cables.
High compatibility
Designed to integrate seamlessly with PC systems, this cable ensures a smooth connection with a wide range of compatible devices. -
Robust design
Featuring twinaxial technology and a direct attach cable design, this product offers durability and reliable performance for critical network connections. -
Optimal operating range
With an operating temperature range from 0°C to 70°C, this cable is built to perform reliably in a variety of environmental conditions.
- Cisco 40GBASE-CR4 Passive Copper Cable - direct attach cable - 1 m - tan
- Direct attach cable
- Technology
- Twinaxial
- Length
- 1 m
- Connector
- QSFP+
- Connector (Second End)
- QSFP+
- Tan
- 90 days warranty
- Designed For
- Catalyst 3016; Nexus 3016, 3064-E, 3064PQ, 3064-X
- Network Cable Type
- Technology
- Twinaxial
- Length
- 1 m
- Tan
- Connector
- QSFP+
- QSFP+
- 90 days warranty
- 0 °C
- 70 °C
- Designed For
- Cisco Catalyst 3016 , Cisco Nexus 3016 Forward Airflow LAN Enterprise License Bundle, 3016 Reversed Airflow LAN Enterprise License Bundle, 3064-E, 3064-E Reversed Airflow LAN Enterprise License Bundle, 3064-E Standard Airflow LAN Enterprise License Bundle, 3064PQ, 3064PQ Front-to-Back Airflow LAN Enterprise License Bundle, 3064-X, 3064-X Forward Airflow Base and LAN Enterprise License Bundle, 3064-X Reversed Airflow Base and LAN Enterprise License Bundle
