Cisco 4-port Dual WAN VPN Router
Quicklinx: 76ZVWS00 Mfr#: RV042-UK
Type: Router
Connection Type: DSL (Cable)
Standards: Ethernet, Fast Ethernet
Speed: 100Mbps
Rackmount or External: External
£125.88 ex VAT
£151.05 inc VAT
Network connections are the backbone of business connections. Cisco Small Business RV042 Virtual Private Networking (VPN) Router supports up to four wired and 50 off-site connections. The latter allows users to connect into your network with secure access to your files and intranet.
The RV042 comes with dual Internet ports that can serve as a failsafe system for 24/7 network uptime, or as a secondary connection to a separate Internet provider. Whether they're used for backup or speed boosting, the router's networking hardware will keep bottlenecks away from your network, period.
Cisco Small Business RV042 - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Performance
NAT throughput: 100 Mbps , VPN throughput (IPSec): 59 Mbps
IPSec VPN tunnels: 50 , PPTP VPN tunnels: 5 , VPN tunnels (remote access): 5
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, Bonjour, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, HTTPS
Firewall protection, switching, DMZ port, routing, NAT support, VPN support, PAT support, load balancing, VLAN support, SPI, content filtering, QoS, IPv4 support
IEEE 802.3, IEEE 802.3u, UPnP
DC 12 V 1 A
13 cm x 20 cm x 3.9 cm
0.58 kg
English / United Kingdom
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, AES, SHA-1
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, UPnP, FCC Class B certified
Status Indicators
Status, LAN, DMZ, DMZ/Internet, diagnostic
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , WAN / DMZ: 1 x 10Base-T/100Base-TX - RJ-45
External power adapter
DC 12 V
Electric Current Required
1 A
1 x network cable , 1 x power cable
OS Provided
Linux
Software Included
Cisco QuickVPN Client
13 cm
20 cm
3.9 cm
0.58 kg
Limited warranty - lifetime
10 - 85%
76ZV C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
76ZV C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.75
76ZV C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Speed: 100Mbps
Brand: Cisco
