The Cisco 3504 Wireless Controller provides centralized control, management, and troubleshooting for small to medium-sized enterprises and branch offices. It offers flexibility to support multiple deployment modes in the same controller - a centralized mode for campus environments, Cisco FlexConnect mode for lean branches managed over the WAN, and a mesh (bridge) mode for deployments in which full Ethernet cabling is unavailable. As a component of the Cisco Unified Wireless Network, the 3504 controller provides real-time communications between Cisco Aironet Access Points, Cisco Prime Infrastructure, and the Cisco Mobility Services Engine, and is interoperable with the Cisco 5520 and 8540 Wireless Controllers.
PERFORMANCE
Optimised to enable 802.11ac Wave 2 next-generation networks; 4 Gbps throughput -
HIGHLY SCALABLE
Supports 150 access points and 3,000 clients; 1x Multi-Gigabit Ethernet interface (up to 5 Gigabit Ethernet); 4 x 1 Gigabit Ethernet; 4,096 VLANs -
FLEXIBILITY
Multiple deployment modes – centralised mode for campus environments, Cisco FlexConnect mode for lean branches managed over the WAN and mesh (bridge) mode for when full Ethernet cabling is unavailable -
PART OF THE CISCO UNIFIED WIRELESS NETWORK
Provides real-time communication between Cisco Catalyst access points, Cisco Catalyst access points, Cisco Prime Infrastructure and the Cisco Mobility Services Engine -
PEACE OF MIND
3-year parts coverage; 90-day software warranty on media and ongoing downloads of BIOS, firmware and drivers
- Cisco Wireless Controller 3504 - network management device - Wi-Fi 5
- Network management device
- Form Factor
- Desktop
- Ports Qty
- 4
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11a, IEEE 802.11g, 10 Gigabit Ethernet, IEEE 802.11n, IEEE 802.11ac Wave 2, IEEE 802.11ac Wave 1
- Performance
- Throughput: 4 Gbps
- Capacity
- Maximum number of access points: 150 , Maximum number of clients: 3000 , VLANs supported: 4096
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- AC 120/230 V (50/60 Hz)
- 4.394 cm x 34.13 cm x 21.59 cm
- 2 kg
- 90 days warranty
- 4.394 cm
- 34.13 cm
- 21.59 cm
- 2 kg
- Form Factor
- Desktop
- Ports Qty
- 4
- TCP/IP, UDP/IP, ICMP/IP, ARP, BOOTP, DHCP
- Routing Protocol
- CIDR
- Remote Management Protocol
- SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH
- Performance
- Capacity
- Status Indicators
- Diagnostic
- Syslog support, IPv6 support, Deep Packet Inspection (DPI), SNTP support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, CleanAir technology, Unified Communications, CAPWAP support, Management Information Base (MIB), Multicast filtering function, Cisco VideoStream technology, Link Aggregation, Management Information Base (MIB) II, Application Visibility and Control (AVC), TrustSec support, Private MIB
- Encryption Algorithm
- DES, Triple DES, RC4, AES, IKE, TLS 1.0, TKIP, WPA, WPA2, PKI, AES-CBC, DTLS, WEP, TLS 1.2, ESP, ISAKMP, CRL, CBS, CCM, CCMP
- Authentication Method
- RADIUS, TACACS, Extensible Authentication Protocol (EAP)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11e, IEEE 802.1ae, IEEE 802.11n, IEEE 802.11k, IEEE 802.1AX, IEEE 802.11w, IEEE 802.11r, IEEE 802.11u, IEEE 802.11ac Wave 2
- 1 x 10GBase-T - RJ-45 , 4 x 1000Base-T - RJ-45 , 1 x console - RJ-45 , 1 x serial - RJ-45 , 1 x redundancy - RJ-45 , 1 x console - mini-USB , 1 x USB 3.0
- EN 61000-3-2, EN55024, AS/NZS 60950-1, ICES-003 Class A, UL 60950-1 Second Edition, FCC CFR47 Part 15 B, HMAC, Directive 2004/108/EC, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, Directive 2006/95/EC, VCCI Class B, KN24, KCC KN22 Class B, CAN/CSA C22.2 No. 60950-1 Second Edition, EN 6100-3-3, EN 55032 Class B, CNS 13438 Class B
- PoE
- Voltage Required
- Limited warranty - replacement - 90 days - response time: 10 days
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
