Based on SIP, the Cisco SPA303 3-line IP phone with 2-port switch helps ensure comprehensive interoperability with equipment from voice over IP (VoIP) infrastructure leaders, enabling service providers to quickly roll out competitive, feature-rich services to their customers. With hundreds of features and configurable service parameters, the Cisco SPA303 addresses the requirements of traditional business users while building on the advantages of IP telephony. Features such as easy station moves and shared line appearances are just some of the many advantages of the SPA303.
The Cisco SPA303 uses standard encryption protocols to perform highly secure remote provisioning and unobtrusive in-service software upgrades. Remote provisioning tools include detailed performance measurement and troubleshooting features, enabling network providers to deliver high-quality support to their subscribers. Remote provisioning also saves service providers the time and expense of managing, preloading, and reconfiguring customer premises equipment.
Comprehensive interoperability and SIP-based feature set
Based on SIP, the Cisco SPA 303 3-line IP phone with 2-port switch helps ensure comprehensive interoperability with equipment from voice over IP (VoIP) infrastructure leaders, enabling service providers to quickly roll out competitive, feature-rich services to their customers. With hundreds of features and configurable service parameters, the Cisco SPA 303 addresses the requirements of traditional business users while building on the advantages of IP telephony. Features such as easy station moves and shared line appearances are just some of the many advantages of the SPA 303. -
Carrier-grade security, provisioning, and management
The Cisco SPA 303 uses standard encryption protocols to perform highly secure remote provisioning and unobtrusive in-service software upgrades. Remote provisioning tools include detailed performance measurement and troubleshooting features, enabling network providers to deliver high-quality support to their subscribers. Remote provisioning also saves service providers the time and expense of managing, preloading, and reconfiguring customer premises equipment.
- Cisco Small Business SPA 303 - VoIP phone
- Product Type
- VoIP phone
- Main Features
- Multiple VoIP protocol support, integrated Ethernet switch
- VoIP Protocols
- SIP, SIP v2, SPCP
- Voice Codecs
- G.722, G.729ab, G.711u, G.711a, G.726
- Lines Supported
- Multiline
- Speakerphone
- Caller ID
- Voice Mail Capability
- Call Services
- Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold
- Automatic Redial
- Speed Dial Capacity
- 8
- Missed Calls Memory
- 60
- Display
- LCD display - monochrome
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX
- Localisation
- United Kingdom
- 1-year warranty
- Product Type
- VoIP phone
- Localisation
- United Kingdom
Phone Features
- Call Services
- Dialer Type
- Keypad
- Dialer Location
- Base
- Conference Call Capability
- Speakerphone
- Automatic Redial
- Menu Operation
- Function Buttons
- Voice mail button, speakerphone button, headset button, mute button, hold button
- Volume Control
- Ringer Control
- Ring Tones
- 10
- Indicators
- Voice message waiting indicator, speakerphone indicator, headset
- Firmware Upgradable
- Additional Functions
- Call timer, built-in clock, Pager Call, automatic redial
- Additional Features
- On-hook dialling, music on hold, built-in web server
IP Telephony
- Main Features
- VoIP
- VoIP Protocols
- SIP, SIP v2, SPCP
- Voice Codecs
- Lines Supported
- Multiline
- Quality of Service
- IEEE 802.1Q (VLAN), Differentiated Services (DiffServ), IEEE 802.1p, Type of Service (ToS)
- IP Address Assignment
- DHCP, static
- Security
- 256 bit AES
- Network Protocols
- IP, TCP, TFTP, UDP, ICMP, ARP, HTTP, DNS, HTTPS
- Network Ports Qty
- Voice Features
- Voice activity detection (VAD)
- Network Features
- Network Address Translation (NAT)
Phone Memory
- Phone Directory Capacity
- 100 names & numbers
- 60
- Dialed Calls Memory
- 60
- Call Log Capacity
- 60 numbers
- 8
Display
- Display Location
- Base
- Display Resolution
- 128 x 64 pixels
- Connections
- Headset jack / sub-mini-phone 2.5mm
- Cables Included
- Network cable
- Included Accessories
- Stand, power adapter
- UL, FCC Part 15 B, A-Tick
- Power adapter - external
Dimensions & Weight (Base)
- 22 cm
- 3 cm
- 19.8 cm
- 0.7 kg
- Limited warranty - 1 year
