Cisco 2TB NSS 322 2-Bay Smart NAS
Quicklinx: 77CXWS00 Mfr#: NSS322D02-K9
  • Atom
Cisco NSS 300 series Smart Storage is a series of desktop network storage solutions that combine class-leading performance with affordability and ease of use. High performance means shorter backup times and faster files sharing across multiple users. The devices are easy to set up, configure, and manage, with a simple, browser-based interface that helps save you time.
Powered by a dual-core Intel Atom processor, Cisco Smart Storage delivers class-leading performance. The fast, efficient backup allows more users to access Cisco Smart Storage simultaneously and enables you to schedule backups at convenient times for your business.
Cisco Smart Storage helps prevent unauthorized access to the device, and enables highly secure remote and web access. Advanced Encryption Standard (AES) 256-bit on-disk data encryption helps protect critical business data, even if the hard drives are stolen, a business-class feature most other storage solutions do not provide.
Cisco Smart Storage is easy to set up, configure, and manage. You can set up the device in minutes and configure it with a straightforward, browser-based interface. To save time on account setup, you can use user account information from your Windows active directory server, allowing employees to access Cisco Smart Storage with their existing login name and password.
  • High-performance system speeds backup and facilitates information sharing
  • Built-in and add-on applications extend usage beyond storage
    Built-in applications include a user-configurable web server with an integrated WordPress publishing platform that allows you to create and run blogs, forums, and internal websites from your Cisco Smart Storage device, and built-in syslog and RADIUS servers that help simplify user authentication and management of your entire network. Running applications like these on a Cisco Smart Storage device helps ensure that they are available at all times and can eliminate the need for additional devices on the network, enabling your business to be more efficient.
  • Security features safeguard your stored data from unauthorized access
  • Simplified configuration and management saves time
  • Reliable, high-availability design means worry-free operation
    Cisco Smart Storage offers Redundant Array of Independent Disks (RAID) 0, 1, 5, and 6 configurations, which helps safeguard your data, and a hot-swap design that allows you to replace a failed drive without turning off the device. You can upgrade a disk configuration to a higher RAID level, or move data to newly installed hard drives, while Cisco Smart Storage is running.
  • Energy-efficient operations save on operating costs and support green initiatives
    Cisco Smart Storage incorporates energy-saving features that save money and support energy conservation initiatives. You can schedule the device to power on and off according to your working hours and use the Wake on LAN feature to power on your Cisco Smart Storage device remotely. Conserve power with an Energy Star V rated power adapter and hard disk drives that spin down on inactivity. Integrated applications help save energy by reducing the number of network-based devices your small business needs.
Cisco Small Business NSS 322 Smart Storage - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
Max Supported Capacity
4 TB
2 (installed) / 2 (max)
10.2 cm x 21.6 cm x 15 cm
English, German, French, Italian, Spanish, Japanese
1 x Intel Atom D510 1.66 GHz (Dual-Core)
Storage Controller
RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
Hard Drive
2 x 1 TB
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
RAM
1 GB
Storage Operating System
Linux 2.6
UNIX, Linux, Apple MacOS X, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits)
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
4 TB
10.2 cm
21.6 cm
15 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
RAM
1 GB DDR2
Flash Memory Installed
512 MB Flash
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 1 TB
S.M.A.R.T., 256-bit AES
Network / Transport Protocol
TCP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DNS, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
DHCP support, trunking, wake on LAN (WOL), Syslog support, manageable, E-mail alert, IPv6 support, IP address filtering, 256-bit encryption, firmware upgradable, web server, RADIUS support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert
IEEE 802.3ad (LACP), DLNA CERTIFIED
Expansion Bays
2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 5 x USB 2.0 - Type A , 2 x eSATA
2 x network cable
FCC Class B certified, UL, C-Tick, WEEE, AES-256
External power adapter
Power Provided
84 Watt
Linux 2.6
Software Included
iTunes Server, Twonky UPnP/DLNA Media Server, RADIUS Server, Web File Manager, Web Server with WordPress Publishing & MySQL Database, Multimedia Station, Download Station, Syslog Server
Limited warranty - 5 years
0 - 95%
