The platforms are architected to enable the next phase of branch-office evolution, providing rich media collaboration and virtualization to the branch while maximizing operational cost savings The integrated services routers generation 2 platforms are future-enabled with multi-core CPUs, support for high capacity DSPs (Digital Signal Processors) for future enhanced video capabilities, high powered service modules with improved availability, Gigabit Ethernet switching with enhanced POE, and energy monitoring and control capabilities while enhancing overall system performance. Overall, the Cisco 2900 series offer unparalleled total cost of ownership savings and network agility through the intelligent integration of market leading security, unified communications, wireless, and application services.
The Cisco 2900 series integrated services router offers embedded hardware encryption acceleration, voice- and video-capable Digital Signal Processor (DSP) slots, intrusion prevention, call processing, voicemail, and application services.
Services integration
The Cisco 2900 series ISRs offer increased levels of services integration with voice, video, security, wireless, mobility, and data services, enabling greater efficiencies and cost savings. -
Services on demand
The Universal image contains all of the Cisco IOS technology sets which can be activated with a software license. This allows your business to quickly deploy advanced features without downloading a IOS image. Additionally, larger default memory is included to support the capabilities. -
High performance with integrated services
The Cisco 2900 series enables deployment in high speed WAN environments with concurrent services enabled up to 75 Mbps. A multigigabit fabric (MGF) enables high-bandwidth module-to-module communication without compromising routing performance. -
Network agility
Designed to address customer business requirements, the Cisco 2900 series modular architecture offers increased capacity and performance as your network needs grow. Modular interfaces offer increased bandwidth, a diversity of connection options, and network resiliency. -
Energy efficiency
The Cisco 2900 series offers intelligent power management and allows the customer to control power to the modules based on the time of day. Cisco EnergyWise technology will be supported in the future. Services integration and modularity on a single platform performing multiple functions, optimizes raw materials consumption and energy usage.
- Cisco 2901 Security Bundle - router - desktop
- Router
- Enclosure Type
- Desktop - modular - 1U
- WAN Ports Qty
- 2
- Data Link Protocol
- IPSec
- Routing Protocol
- OSPF, IS-IS, BGP, EIGRP, DVMRP, PIM-SM, IGMPv3, GRE, PIM-SSM, static IPv4 routing, static IPv6 routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP, RMON
- Firewall protection, hardware encryption, VPN support, MPLS support, Syslog support, content filtering, IPv6 support, CBWFQ, WRED, DMVPN
- IEEE 802.1Q, IEEE 802.3af, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag
- Power
- AC 120/230 V (50/60 Hz)
- 43.8 cm x 43.9 cm x 4.5 cm
- 6.1 kg
- 90 days warranty
- Router
- Enclosure Type
- Connectivity Technology
- Wired
- IPSec
- Routing Protocol
- SNMP, RMON
- Encryption Algorithm
- SSL
- IEEE 802.1Q, IEEE 802.3af, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag, CISPR 22 Class A, CISPR 24, EN55024, EN55022 Class A, EN50082-1, CAN/CSA-E60065-00, ICES-003 Class A, CS-03, AS/NZS 3548, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60065, BSMI CNS 13438, EN 300 386
- RAM
- 512 MB (installed) / 2 GB (max)
- Flash Memory
- 256 MB (installed) / 8 GB (max)
- Status Indicators
- Power, link/activity
- 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x console - RJ-45 , Management: 1 x console - mini-USB Type B , Serial: 1 x auxiliary - RJ-45 , USB: 2 x 4 pin USB Type A
- Expansion Slots
- 4 (total) / 4 (free) x EHWIC , 2 (total) / 2 (free) x PVDM , 2 (total) / 1 (free) x CompactFlash , 1 (total) / 1 (free) x ISM
- Power Device
- Internal power supply
- Voltage Required
- Rack Mounting Kit
- Included
- OS Provided
- Cisco IOS Security
- 43.8 cm
- 43.9 cm
- 4.5 cm
- 6.1 kg
- Limited warranty - 90 days
- 0 °C
- 40 °C
- 10 - 85%
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
