The Cisco 2900 series offer unparalleled total cost of ownership savings and network agility through the intelligent integration of market leading security, unified communications, wireless, and application services.
The Cisco 2900 series ISRs offer embedded hardware encryption acceleration, voice- and video-capable digital signal processor (DSP) slots, optional firewall, intrusion prevention, call processing, voicemail, and application services. In addition, the platforms support the industries widest range of wired and wireless connectivity options such as T1/E1, xDSL, copper and fiber GE.
Services integration
The Cisco 2900 series ISRs offer increased levels of services integration with voice, video, security, wireless, mobility, and data services, enabling greater efficiencies and cost savings. -
Services on demand
The Cisco Services Ready Engine (SRE) enables a new operational model which allows you to reduce capital expenditures (CapEx) and deploy a variety of application services as needed on a single integrated compute services module. -
High performance with integrated services
The Cisco 2900 series enables deployment in high speed WAN environments with concurrent services enabled up to 75 Mbps. A multigigabit fabric (MGF) enables high-bandwidth module-to-module communication without compromising routing performance. -
Network agility
Designed to address customer business requirements, the Cisco 2900 series modular architecture offers increased capacity and performance as your network needs grow. Modular interfaces offer increased bandwidth, a diversity of connection options, and network resiliency.
- Cisco 2901 - router - rack-mountable
- Router
- Enclosure Type
- Rack-mountable - modular - 1U
- WAN Ports Qty
- 2
- Data Link Protocol
- IPSec, L2TPv3
- Routing Protocol
- OSPF, IS-IS, BGP, EIGRP, DVMRP, PIM-SM, static IP routing, IGMPv3, GRE, PIM-SSM, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), MPLS, Bidirectional Forwarding Detection (BFD), IPv4-to-IPv6 Multicast
- Remote Management Protocol
- SNMP, RMON, TR-069
- Firewall protection, VPN support, MPLS support, Syslog support, IPv6 support, CBWFQ, WRED, WSMA, NetFlow
- IEEE 802.3, IEEE 802.1Q, IEEE 802.3af, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag, ANSI T1.101, ITU-T G.823, ITU-T G.824
- Power
- AC 120/230 V (50/60 Hz)
- 43.8 cm x 43.9 cm x 4.5 cm
- 6.1 kg
- 90 days warranty
- Router
- Enclosure Type
- Connectivity Technology
- Wired
- IPSec, L2TPv3
- Routing Protocol
- IEEE 802.3, IEEE 802.1Q, IEEE 802.3af, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag, ANSI T1.101, ITU-T G.823, ITU-T G.824, CISPR 22 Class A, CISPR 24, EN55024, EN55022 Class A, EN50082-1, AS/NZS 60950-1, ICES-003 Class A, CS-03, R&TTE, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, AS/NZS 3548 Class A, VCCI V-3, EN 61000, TIA/EIA/IS-968, EN 300 386, CAN/CSA-C22.2 No. 60950-1
- RAM
- 512 MB (installed) / 2 GB (max)
- Flash Memory
- 256 MB (installed) / 8 GB (max)
- Status Indicators
- Power, link/activity
- 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x console - RJ-45 , Management: 1 x console - mini-USB Type B , Serial: 1 x auxiliary - RJ-45 , USB: 2 x 4 pin USB Type A
- Expansion Slots
- 4 (total) / 4 (free) x EHWIC , 2 (total) / 2 (free) x PVDM , 2 (total) / 1 (free) x CompactFlash , 1 (total) / 1 (free) x ISM
- Power Device
- Internal power supply
- Voltage Required
- Rack Mounting Kit
- Included
- OS Provided
- Cisco IOS IP Base
- 43.8 cm
- 43.9 cm
- 4.5 cm
- 6.1 kg
- Limited warranty - 90 days
- 0 °C
- 40 °C
- 10 - 85%
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
