Cisco Systems is redefining best-in-class routing with a new line of integrated services routers that are optimized for the secure delivery of concurrent data, voice, and video services. Founded on 20 years of leadership and innovation, the modular Cisco 2800 integrated services routers ship with the industry's most comprehensive security services, intelligently embedding data, security, and voice into a single, resilient system for fast, scalable delivery of mission-critical business applications. The Cisco 2800 routers are ideal for small businesses and enterprise branch offices, delivering a rich, integrated solution for connecting remote offices, mobile users, and partner extranets or service provider-managed customer premises equipment (CPE).
- Cisco 2801 Security Bundle - router - desktop
- Router
- Enclosure Type
- Desktop - modular - 1U
- Data Link Protocol
- Ethernet, Fast Ethernet
- IPSec
- Remote Management Protocol
- SNMP 3
- Modular design, firewall protection, 128-bit encryption, hardware encryption, VPN support, MPLS support, URL filtering, 256-bit encryption
- 44.5 cm x 41.9 cm x 4.37 cm
- 6.2 kg
- Router
- Enclosure Type
- Connectivity Technology
- Wired
- IPSec
- SNMP 3
- Encryption Algorithm
- DES, Triple DES, AES
- CISPR 22 Class A, CISPR 24, EN 61000-3-2, VCCI Class A ITE, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950, EN50082-1, CSA 22.2 No. 60950, AS/NZ 3548 Class A, JATE, FCC Part 15, ICES-003 Class A, CS-03, EN 61000-6-2
- RAM
- 256 MB (installed) / 384 MB (max) - SDRAM
- Flash Memory
- 64 MB (installed) / 128 MB (max)
- Status Indicators
- Power, link/activity
- 2 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x , Management: 1 x console - RJ-45 , 1 x auxiliary - RJ-45
- Expansion Slots
- 2 (total) / 2 (free) x HWIC , 2 (total) / 2 (free) x AIM , 2 (total) / 2 (free) x PVDM , 1 (total) / 1 (free) x WIC , 1 (total) / 1 (free) x VIC , 1 memory , 1 CompactFlash
- Power Device
- Internal power supply
- OS Provided
- Cisco IOS Advanced Security
- 44.5 cm
- 41.9 cm
- 4.37 cm
- 6.2 kg
- 0 °C
- 40 °C
- 10 - 85%
