The Cisco SG500-28P is a 28-port stackable managed Gigabit Ethernet switch, including 2 combination ports and 2 Small Form-Factor Pluggable (SFP) ports, that provides a solid foundation for your current business applications, as well as those you are planning for the future. It offers Power over Ethernet Plus, true stacking, advanced security, quality of service, energy-saving technology (EEE), IPv6, and network features that deliver the reliability and performance needed by demanding environments. The switch is easy to configure and manage with a choice of management tools. The Cisco SG500-28P provides the ideal technology foundation at a price you can afford, and in a solution designed to grow with your business.
- Cisco Small Business SG500-28P - switch - 28 ports - Managed - rack-mountable
- Switch - 28 ports - Managed - stackable
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 2 x combo Gigabit SFP + 2 x SFP
- Power Over Ethernet (PoE)
- PoE
- Routing Protocol
- Static IP routing
- Flow control, Layer 2 switching, VLAN support, IPv6 support, STP support, RSTP support, MSTP support, ACL support, QoS, reset button, LACP support, Energy Efficient Ethernet, GVRP
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 25.7 cm x 4.4 cm
- 4 kg
- Localisation
- Europe
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- Routing Protocol
- Static IP routing
- RAM
- 256 MB
- Flash Memory
- 32 MB
- Status Indicators
- Port transmission speed, system, PoE, link/activity
- 26 x 1000Base-T RJ-45 PoE , 2 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- Cables Included
- 1 x serial cable
- UL 60950, FCC Part 15 A, CSA 22.2
- Localisation
- Europe
- 44 cm
- 25.7 cm
- 4.4 cm
- 4 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 1 year , Technical support - web support - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.68 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.87 |
