The Cisco Catalyst Series Switches support dual redundant power supplies. The switch ships with one power supply by default, and the second power supply can be purchased at the time of ordering the switch or at a later time. If only one power supply is installed, it should always be in power supply bay 1. The switch also ships with three field-replaceable fans.
POWER
250W AC power supply module; supports input voltages between 100 and 240 VAC -
COMPATIBILITY
For use with Cisco Catalyst 3650 series network switches -
INTERNAL FAN
Built-in fan for cooling power supply module -
FLEXIBLE DEPLOYMENT
Can be used alone or in combination with another AC power supply module -
PEACE OF MIND
Enhanced limited lifetime warranty
- Cisco - power supply - 250 Watt
- Power supply - plug-in module
- Input Voltage
- AC 100-240 V
- Power Capacity
- 250 Watt
- Pricing Type
- Field Replaceable Unit (FRU)
- Designed For
- Catalyst 2960XR-24PD-I (250 Watt), 2960XR-24PS-I (250 Watt), 2960XR-24TD-I (250 Watt), 2960XR-24TS-I (250 Watt), 2960XR-48FPD-I (250 Watt), 2960XR-48FPS-I (250 Watt), 2960XR-48LPD-I (250 Watt), 2960XR-48LPS-I (250 Watt), 2960XR-48TD-I (250 Watt), 2960XR-48TS-I (250 Watt)
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Capacity
- 250 Watt
- Cooling fan
- Pricing Type
- Designed For
- Cisco Catalyst 2960XR-24PD-I (250 Watt), 2960XR-24PS-I (250 Watt), 2960XR-24TD-I (250 Watt), 2960XR-24TS-I (250 Watt), 2960XR-48FPD-I (250 Watt), 2960XR-48FPS-I (250 Watt), 2960XR-48LPD-I (250 Watt), 2960XR-48LPS-I (250 Watt), 2960XR-48TD-I (250 Watt), 2960XR-48TS-I (250 Watt)
