Next-generation 250 Series Smart Switches combine powerful performance and reliability with a suite of features that you need for a solid business network. With Smart Network Application, FindIT Network Manager, and Network Plug and Play (PnP) support, you can deploy and configure a complete business network in minutes.
ETHERNET PORT CONFIGURATION
48-port 10/100/1000, 2 x 1G combo SFP -
POWER OVER ETHERNET
48 PoE ports with 192W total power budget, PoE, PoE+ -
CONFIGURATION & CONTROL
Easy-to-use on-box WebUI, CLI offers basic+ capabilities, SNMP, Cisco FindIT Network Manager, PnP, auto-discovery, zero-touch deployment -
L2+ FEATURES AND SECURITY
Static routing, VLANs, QoS, Voice VLAN, MSTP, IGMP Snooping Access Control List (ACL), 802.1X, DoS prevention, SSH/SSL -
PEACE OF MIND
Limited-lifetime warranty, one-year technical support, and free software fixes for the term of the warranty
 - Cisco 250 Series SG250-50HP - switch - 50 ports - smart - rack-mountable
 - Switch - 50 ports - L3 - smart
- Enclosure Type
 - Rack-mountable 1U
- Subtype
 - Gigabit Ethernet
- Ports
 - 48 x 10/100/1000 (PoE+) + 2 x combo Gigabit Ethernet/Gigabit SFP
- Power Over Ethernet (PoE)
 - PoE+
- PoE Budget
 - 192 W
- Performance
 - Switching capacity: 100 Gbps , Switching capacity (64-byte packet size): 74.41 Mpps
- Capacity
 - MSTP instances: 8 , Active VLANs: 256 , QoS hardware queues: 4
- MAC Address Table Size
 - 8K entries
- Jumbo Frame Support
 - 9KB
- Routing Protocol
 - IGMPv2, IGMP, IGMPv3, MLDv2, MLD, CIDR
- Remote Management Protocol
 - SNMP, RMON, Telnet, HTTP, HTTPS, TFTP, SSH
 - DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, Unicast Storm Control, SNTP support, STP support, RSTP support, MSTP support, ACL support, QoS, MLD snooping, 24 MB packet buffer, SNMP support, 2 fans, Cisco Discovery Protocol
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az
- Power
 - AC 100-240 V (50 - 60 Hz)
 - 44 cm x 35 cm x 4.4 cm
 - 4.8 kg
- Localisation
 - Kuwait, Qatar, Saudi Arabia, Hong Kong, Malaysia, Singapore, United Kingdom
 - Limited lifetime warranty
- Enclosure Type
 - Rack-mountable 1U
- Subtype
 - Gigabit Ethernet
- Ports
 - PoE+
- PoE Budget
 - 192 W
- Performance
- Capacity
 - 8K entries
 - 9KB
- Routing Protocol
- Encryption Algorithm
 - MD5, SSL
- Authentication Method
 - RADIUS
- Processor
 - X ARM: 800 MHz
- RAM
 - 512 MB
- Flash Memory
 - 256 MB
- Status Indicators
 - System, link/speed
 - 48 x 1000Base-T RJ-45 PoE+ - 192 W , 2 x 1000Base-T RJ-45 , 2 x Gigabit LAN SFP , 1 x USB Type A management
- Power Device
 - Internal power supply
- Voltage Required
- Rack Mounting Kit
 - Included
- MTBF
 - 62,607 hours
 - UL 60950, FCC Part 15 A, CSA 22.2
- Localisation
 - 44 cm
 - 35 cm
 - 4.4 cm
 - 4.8 kg
 - Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
 - 0 °C
 - 50 °C
 - 10 - 90% (non-condensing)
- Min Storage Temperature
 - -20 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
