Next-generation 250 Series Smart Switches combine powerful performance and reliability with a suite of features that you need for a solid business network. With Smart Network Application, FindIT Network Manager, and Network Plug and Play (PnP) support, you can deploy and configure a complete business network in minutes.
ETHERNET PORT CONFIGURATION
8-SFP slots 10/100/1000, 2 x 1G uplinks -
CONFIGURATION & CONTROL
Easy-to-use on-box WebUI, CLI, SNMP, Cisco FindIT Network Manager, PnP, Auto Smartports, auto-discovery, zero-touch deployment -
L2+/L3 FEATURES
Static routing, QoS, Voice/Guest VLAN, GVRP, MSTP, IGMP Snooping, Time-based Access Control Lists -
ADVANCED SECURITY
802.1x including DVA, Web-based Authentication, IP/MAC Binding, Private VLAN Edge, IPv6 First Hop Security, IP Source Guard -
PEACE OF MIND
Limited-lifetime warranty, next-business-day replacement, one-year technical support, and free software fixes for the term of the warranty
- Cisco 250 Series SG350-10SFP - switch - 10 ports - Managed
- Switch - 10 ports - L3 - Managed
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8 x Gigabit SFP + 2 x combo Gigabit Ethernet/Gigabit SFP
- Performance
- Switching capacity: 20 Gbps , Forwarding performance (64-byte packet size): 14.88 Mpps
- Capacity
- Active VLANs: 4096
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9216 bytes
- Routing Protocol
- Static IPv4 routing, CIDR
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI
- Layer 3 switching, Layer 2 switching, DHCP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, TFTP support, ACL support, QoS, Jumbo Frames support, MLD snooping, fanless, 1.5MB packet buffer
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 27.9 cm x 17 cm x 4.4 cm
- 2.08 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16K entries
- 9216 bytes
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 512 MB
- Flash Memory
- 256 MB
- Status Indicators
- Link/activity
- 8 x Gigabit LAN SFP , 2 x 1000Base-T RJ-45/SFP , 1 x console RJ-45 management , 1 x USB management
- Power Device
- External power adapter
- Voltage Required
- Cables Included
- 1 x power cable , 1 x console cable
- Rack Mounting Kit
- Included
- MTBF
- 851,827 hours
- UL 60950, FCC Part 15 A, CSA 22.2
- Localisation
- United Kingdom
- 27.9 cm
- 17 cm
- 4.4 cm
- 2.08 kg
- Limited warranty - replacement - lifetime - response time: next business day ¦ Technical support - web support - 1 year ¦ Technical support - phone consulting - 1 year
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
