                VERSATILEIP phone adapter brings traditional analogue devices into the IP world
                AUDIOClear, natural-sounding voice quality via advanced preprocessing, high-performance echo cancellation, voice activity detection and comfort noise generation
                SECURITYSupports the latest encryption with Transport Layer Security (TLS), Secure Hash Algorithm (SHA-2) and new Secure Real-time Protocol (sRTP) cipher suites
                HARDWARETwo RJ-11 FXS ports and two 10/100 Mbps RJ-45 Ethernet ports
                PEACE OF MIND1-year limited hardware warranty
- Cisco ATA 192 Multiplatform Analog Telephone Adapter - VoIP phone adapter
- Form Factor
- External
- Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet
- VoIP Protocols
- SIP, RTP, RTCP, SRTP
- Telephony Interfaces
- 2 phone (FXS)
- Power
- AC 120/230 V / DC 5 V (50/60 Hz)
- 10 cm x 10 cm x 2.8 cm
- 132.1 g
- 1-year warranty
- 10 cm
- 10 cm
- 2.8 cm
- 132.1 g
- Form Factor
- External
- Ports Qty
- 2
- Connectivity Technology
- Wired
- TCP/IP, UDP/IP, RTCP, RTP, ARP, PPPoE, IPSec, PPTP, L2TP
- Remote Management Protocol
- TR-069, HTTP, HTTPS, TFTP, SSH, SNMP 3
- Status Indicators
- Internet, phone, power
- IPv6 support, reset button, wall mountable, DHCP client, Internet Control Message Protocol (ICMP), SNTP support, Cisco Discovery Protocol, LLDP support, NAT support, port forwarding, DiffServ support, Type of Service (ToS), Automated Attendant (IVR), Syslog support, dual image support
- Encryption Algorithm
- ESP, AES, TLS 1.1, TLS 1.2
- Authentication Method
- Secure Shell (SSH)
- IEEE 802.1ab (LLDP), IEEE 802.1p, IEEE 802.1Q
IP Telephony
- VoIP Protocols
- Voice Codecs
- G.711a, G.711µ, G.726, G.729a, G.729ab, T.38, G.711
- 2 phone (FXS)
- IP Telephony Features
- Call waiting, call forwarding, call hold, caller ID block/unblock, Caller ID, call transfer, distinctive ringing, Do-not-disturb (DND) support
- 2 x FXS - RJ-11 , 2 x 100Base-TX - RJ-45
- MTBF
- 300,000 hours
- Directive 2014/30/EU, Directive 2014/35/EU, UL 60950 Second Edition, CAN/CSA C22.2 No. 60950 Second Edition, IEC 60950-1:2005 Second Edition, AS/NZS 60950-1:2015, AS/NZS CISPR32:2015 Class B, CISPR 32:2015 Class B, EN 55032:2015 Class B, EN 61000-3-2:2014 Class A, EN 61000-3-3:2013, EN 55024:2010+A1:2015, EN 61000-4-2, EN 61000-4-3, EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, EN 61000-4-8, EN 61000-4-11, FCC Part 15 B, ANSI C63.4-2014, ICES-003:2016
- Power Device
- External power adapter
- Voltage Required
- 5 Watt
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
