Cisco 2-Port 2nd Gen Multiflex TrunkVoice/WAN Int. Card
Quicklinx: 75BWWS00 Mfr#: VWIC2-2MFT-G703
The Cisco Second-generation T1/E1 Multiflex Trunk Voice/WAN Interface (MFT VWIC2) supports data and voice applications on the Cisco 1721 (data only), 1751 and 1760 Modular Access Routers, the Cisco 2600XM Multiservice Router, the Cisco 2691 Multiservice Platform, the Cisco 3662 Telco Versatile DCN Access Platform, the Cisco 3725 and 3745 Multiservice Routers, and the Cisco 1841 (data only), 2801, 2811, 2821, 2851, 3825, and 3845 Integrated Services Routers. The Cisco MFT VWIC2 combines WAN-interface-card (WIC) and voice-interface-card (VIC) functions to provide unparalleled flexibility, versatility, and investment protection through its many uses. Customers who choose to integrate data and voice in multiple steps preserve their investment in a T1/E1 WAN interface because the Cisco MFT VWIC2 cards can be reused in packet voice applications.
Cisco Multiflex Trunk Voice/WAN Interface Card G.703 2nd Generation - expansion module - 2 ports
Expansion module
Plug-in module
7.9 cm x 12.2 cm x 2.1 cm
62 g
Ports Qty
2 ports
Data Transfer Rate
2.048 Mbps
Line Rate
T-1/E-1
Cisco 1921, 1921 4-pair, 1921 ADSL2+, 1941, 2801, 2801 2-pair, 2801 4-pair, 2801 V3PN, 2811, 2811 2-pair, 2811 4-pair, 2811 V3PN, 2821, 2821 4-pair, 2821 V3PN, 2851, 2851 V3PN, 2901, 2911, 2921, 2951, 3825, 3825 V3PN, 3845, 3845 V3PN, 3925, 3925E, 3945, 3945E
Expansion module - 2 ports
Plug-in module
Wired
Data Transfer Rate
2.048 Mbps
Line Rate
T-1/E-1
Line Coding Format
AMI, B8ZS, HDB3
Status Indicators
Carrier detect, alarm
2 x T1/E1 - RJ-48
Compatible Slots
1 x Expansion Slot
FCC Class B certified, VCCI Class B ITE, CISPR 22 Class B, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, UL 60950, CSA 22.2 No. 60950, EN55022 Class B, ICES-003 Class B, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, AS/NZS 3548, EN 61000-4-5, EN 61000-6-2, EN 61000-4-11, FCC CFR47 Part 15, EN 61000-4-8, IEC 60950-1, EN 60950-1, EN 300 386
7.9 cm
12.2 cm
2.1 cm
62 g
5 - 85%
Cisco 1921, 1921 4-pair G.SHDSL bundle, 1921 ADSL2+ Bundle, 1941, 1941 Mobile Wireless, 1941 Secure WAAS Bundle, 1941 Security, 1941 WAAS Bundle, 2801, 2801 Unified Communications Bundle, 2801 Unified Communications Bundle with Advanced Security, 2811, 2811 Terminal Server Bundle, 2811 Unified Communications Bundle, 2811 Unified Communications Bundle with Advanced Security, 2811 WAN Application Acceleration Bundle, 2821, 2821 Branch Office in a Box Bundle, 2821 Secure WAN Optimization Bundle, 2821 Unified Communications Bundle, 2821 Unified Communications Bundle with Advanced Security, 2821 WAN Application Acceleration Bundle, 2821 WAN Optimization Bundle, 2851, 2851 Secure WAN Optimization Bundle, 2851 Unified Communications Bundle, 2851 Unified Communications Bundle with Advanced Security, 2851 WAN Application Acceleration Bundle, 2851 WAN Optimization Bundle, 2901, 2901 Secure WAAS Bundle, 2901 Terminal Server Bundle, 2901 Voice Security and CUBE Bundle, 2901 WAAS Bundle, 2911, 2911 Secure WAAS Bundle, 2911 UCSE Bundle, 2911 Voice Security and CUBE Bundle, 2911 WAAS Bundle, 2921, 2921 Secure WAAS Bundle, 2921 Voice Security and CUBE Bundle, 2921 WAAS Bundle, 2951, 2951 Secure WAAS Bundle, 2951 Voice Security and CUBE Bundle, 2951 WAAS Bundle, 3825, 3825 Branch Office in a Box Bundle, 3825 Secure WAN Optimization Bundle, 3825 SRST Voice Upgrades for HSEC Bundle, 3825 Unified Communications Bundle, 3825 Unified Communications Bundle with Advanced Security, 3825 WAN Application Acceleration Bundle, 3825 WAN Optimization Bundle, 3845, 3845 Branch Office in a Box Bundle, 3845 Unified Communications Bundle with Advanced Security, 3845 WAN Application Acceleration Bundle, 3845 WAN Optimization Bundle, 3925, 3925 Voice Security and CUBE Bundle, 3925 WAAS Bundle, 3925E, 3925E Voice Security and CUBE Bundle, 3945, 3945 PSRE Bundle, 3945 Voice Security and CUBE Bundle, 3945 WAAS Express Bundle, 3945E
