Cisco 2.4 GHZ 6 DBI/5 GHZ 6 DBI Antenna
Quicklinx: 8VXZWS00 Mfr#: AIR-ANT2566P4W-R=
Type: Antennas
£450.81 ex VAT
£540.97 inc VAT
The Cisco Aironet AIR-ANT2566P4W-R= Dual-Band Directional Wi-Fi Patch Antenna is designed with improved coverage and performance in mind. This FCC-approved patch antenna directs the energy it receives from the transmitter to provide more energy in one direction and less energy in all other directions.
  • PATCH ANTENNA
    6 dBi (2.4 GHz)/6 dBi (5 GHz); 4 dual-band ports; designed for use with dual-band port access points such as the Aironet 1830, 1850, 2800 and 3800 Series and Cisco Catalyst 9115AX, 9120AX and 9130AX Series
  • CONNECTION AND MOUNT
    4 plenum-rated 36-inch cables and RP-TNC connectors; wall mount
  • DIRECTED RADIATION PATTERN
    Intended for deployment when directed coverage is required
  • PERFORMANCE
    Designed for improved directional coverage
  • PEACE OF MIND
    1-year limited hardware warranty
Cisco Aironet Dual Band Antenna - antenna
Antenna
Frequency Range
2.4 GHz, 5 GHz
Gain
6 dBi
Directivity
Directional
Antenna
Aerial
Frequency Range
2.4 GHz, 5 GHz
Gain
6 dBi
Directivity
Directional
Type: Antennas
Brand: Cisco
