Cisco 12 Port 10/100 PoE Compact Switch
Quicklinx: 5K3SWS00 Mfr#: WS-C3560-12PC-S
The Cisco Catalyst 3560 series is a line of fixed-configuration, enterprise-class switches that include IEEE 802.3af and Cisco pre-standard Power over Ethernet (PoE) functionality in Fast Ethernet and Gigabit Ethernet configurations. The Cisco Catalyst 3560 is an ideal access layer switch for small enterprise LAN access or branch-office environments, combining both 10/100/1000 and PoE configurations for maximum productivity and investment protection while enabling the deployment of applications such as IP telephony, wireless access, video surveillance, building management systems, and remote video kiosks. Customers can deploy network-wide intelligent services - such as advanced quality of service (QoS), rate limiting, access control lists (ACLs), multicast management, and high-performance IP routing - while maintaining the simplicity of traditional LAN switching.
Cisco Catalyst 3560-12PC - switch - 12 ports - Managed
Switch - 12 ports - L3 - Managed
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
12 x 10/100 (PoE) + 1 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
12K entries
Routing Protocol
RIP-1, RIP-2, HSRP, static IP routing, policy-based routing (PBR), RIPng
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, FTP, TFTP, SSH-2
Auto-sensing per device, IP-routing, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, traffic shaping, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, ACL support, QoS, Jumbo Frames support, MLD snooping, DAI, PVST+
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
27 cm x 23 cm x 4.4 cm
2.3 kg
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
PoE
12K entries
Routing Protocol
Authentication Method
Kerberos, RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
128 MB
Flash Memory
32 MB Flash
Status Indicators
Port status, port transmission speed, port duplex mode, power, system, link/activity
12 x 100Base-TX RJ-45 PoE , 1 x 1000Base-T RJ-45 , 1 x console RJ-45 management , 1 x SFP (mini-GBIC)
Internal power supply
Rack Mounting Kit
Optional
MTBF
406,470 hours
FCC Class A certified, UL, TUV GS, cUL, EN 60950, EN55022, NOM, VCCI Class A ITE, IEC 60950, EN55024, UL 60950 Third Edition, CB, AS/NZ 3548 Class A, FCC Part 15, CSA C22.2 No. 60950-00, MIC
Software Included
Cisco IOS IP Base
27 cm
23 cm
4.4 cm
2.3 kg
Limited warranty - lifetime
45 °C
10 - 85%
5K3S Cisco 19in RackMount for Catalyst 3560,2960,ME-3400 In Stock £52.90
