The Cisco 100BASE-FX Small Form-factor Pluggable (SFP) is a hot-swappable input/output device that plugs into a Fast Ethernet port or slot, linking the port with the network. The Cisco 100BASE-FX SFP operates on ordinary multimode fiber-optic (MMF) link spans up to 2 kilometers long.
 - Cisco - SFP (mini-GBIC) transceiver module - 100Mb LAN
 - SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
 - Plug-in module
- Cabling Type
 - 100Base-FX
- Optical Wave Length
 - 1310 nm
- Data Link Protocol
 - 100Mb LAN
- Max Transfer Distance
 - 2 km
 - 1.34 cm x 5.65 cm x 8.5 mm
 - 90 days warranty
- Designed For
 - Catalyst 2960, 2960-24, 2960-48, 2960G-24, 2960G-48, 2960S-24, 2960S-48, 3560, 3560-12
- Form Factor
 - Plug-in module
- Connectivity Technology
 - Wired
- Cabling Type
 - 100Base-FX
 - 100Mb LAN
 - 1310 nm
 - 2 km
 - IEEE 802.3, IEEE 802.3ah
 - 1 x Ethernet 100Base-FX - LC multi-mode x 2
- Compatible Slots
 - 1 x SFP (mini-GBIC)
 - 1.34 cm
 - 5.65 cm
 - 8.5 mm
 - Limited warranty - 90 days
 - 0 °C
 - 50 °C
- Designed For
 - Cisco Catalyst 2960-24LC-S, 2960-24PC-L, 2960-24PC-S, 2960-24TC, 2960-24TC-L, 2960-24TC-S, 2960-48PST-L, 2960-48PST-S, 2960-48T, 2960-48TC, 2960-48TC-L, 2960-48TC-S, 2960-8TC, 2960-8TC-S, 2960G-24TC, 2960G-48TC, 2960G-8TC, 2960S-24PD-L, 2960S-24PS-L, 2960S-24TD-L, 2960S-24TS-L, 2960S-24TS-S, 2960S-48FPD-L, 2960S-48FPS-L, 2960S-48LPD-L, 2960S-48LPS-L, 2960S-48TD-L, 2960S-48TS-L, 2960S-48TS-S, 3560-12PC, 3560-12PC-S, 3560-8PC
