Cisco 1000BASE-T SFP Transceiver
Quicklinx: CZV1WS00 Mfr#: GLC-TE=
More than 50 In Stock
£177.54 ex VAT
£213.04 inc VAT
Standard delivery Delivered within 3-5 working days
Cisco SFP (mini-GBIC) transceiver module with Gigabit Ethernet for Cisco 20-port 1-Gigabit; Nexus 7700 F3-Series, 9372PX, 9396PX
  • Efficient connectivity
    The Cisco SFP (mini-GBIC) transceiver module offers wired connectivity technology, ensuring a stable and efficient link for network communications. Its Gigabit Ethernet data link protocol supports a data transfer rate of 1 Gbps, making it ideal for high-speed data transmission needs.
  • Versatile temperature range
    Designed to operate in a wide range of temperatures, this module can function optimally in environments as cold as -5°C and as hot as 85°C. This feature ensures reliable performance in various operating conditions.
  • Easy integration
    With its plug-in module form factor and hot swap module replacement feature, this transceiver module can be easily integrated into existing network setups without significant downtime, facilitating seamless upgrades and maintenance.
Cisco - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
1GbE
Cisco 20-port 1-Gigabit Ethernet Modular Port Adapter; Catalyst ESS9300 Embedded Series; Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118; Nexus 7700 F3-Series 48-Port Fiber 1 and 10G Ethernet Module, 93108TC-EX, 93180YC-FX, 9336C-FX2, 9372PX, 9372PX-E, 9396PX, 9396PX Hot Air Exhaust
Plug-in module
Wired
Cabling Type
1000Base-T
1GbE
Data Transfer Rate
1 Gbps
Full duplex capability, hot swap module replacement
IEEE 802.3
1 x Ethernet 1000Base-T - RJ-45
-5 °C
85 °C
Cisco 20-port 1-Gigabit Ethernet Modular Port Adapter , Cisco Catalyst ESS9300 Embedded Series , Cisco Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118 , Cisco Nexus 7700 F3-Series 48-Port Fiber 1 and 10G Ethernet Module, 93108TC-EX, 93180YC-FX, 9336C-FX2, 9372PX, 9372PX-E, 9396PX, 9396PX Hot Air Exhaust
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: CZV1 050451
Condition: item has been used and came back with no packaging
This part of the stock item is not present or functional  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is not present or functional  £25.89
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Cisco
Stock Status: Used Stock
